JDM VS USDM climate control
Noob question
im planing to convert my interior to complete JDM
will the jdm climate control will work on my usdm eg...
is it just plug an play or do i have to modify it to make it work...thx in advance
also if anyone knw a person or a shop that can do carbon fiber ac/radio bezel let me know
even a black one is good...i dont like grey oem
Nope, the JDM climate control is a *real* climate control in that it has sensors that regulate the temperature. It is all-electric while the USDM climate control is mechanical/electric driven. On the bottom of the USDM control, you'll see a cable attached to a lever that controls your thermostat (thus, mechanical). The JDM CC doesn't have this cable.
You have a couple of options if you want a JDM climate control to match your JDM interior:
- do the whole conversion right by getting JDM heater core, sensors, wiring, etc. Expensive, hard to find all of the parts, and difficult to do, but it's been done. I think someone has done a writeup on the web. Might be easier if you're going to install a RHD dash (are you doing a RHD conversion too?)
- swap the faceplate of your USDM climate control with the JDM and install an orange bulb. Easy, but expensive and kind of a waste of a perfectly good climate control unit. Obviously, most people go this route.
- you could also JDM-ize your USDM climate control a couple of ways...either 1) put 2 orange bulbs in there and call it a day or 2) do it the right way and put amber plastic sheeting from a tail lamp repair kit inside the USDM CC face and leave the stock bulbs in. This way you leave the red/blue temp graphics clear but amber everything else. You'll avoid running an orange light behind the red/blue temp graphics, making it look like @ss. I did this and posted a thread about it awhile back.
fm
fm
paint the DIN. thats what its called
and ask this jdm stuff in the officail ferio thread
they are all jdm wierdos, they can answer any jdm fitment question
