3rd gear grinding
Old Aug 23, 2002 | 11:28 PM
AznInvasion's Avatar
Default 3rd gear grinding
today i noticed that my 3rd gear would grind after i hit VTEC. when i shift before 5k it doesnt grind. all my other gears go in fine. does any1 know what the problem is? the tranny only has like 30k on it and i dont beat on my tranny at all. i only shift hard when i race.
Old Aug 23, 2002 | 11:37 PM
Veil_Side_'s Avatar
Default Re: 3rd gear grinding (AznInvasion)
try checking your tranny fluid level. 5th gear grinds on the rents accord but that was after 50,000 miles of horrific shifting.
Old Aug 24, 2002 | 12:38 AM
CRXBoy's Avatar
Default Re: 3rd gear grinding (Veil_Side_)
couldm be ur sincrros(SP) my are shot in third gear too
Old Aug 24, 2002 | 06:15 AM
USDM 4G VTEC's Avatar
my car started doign that on 3rd.. then i check the oil level on the tranny, added some and 3rd stopped and now its 4th... always grinds when i shift into 4th... anyways, a guy in G2IC, told me that a good way to fix that , since the synchros are oil activated, its to raise the car real high from the pass side... add oil until bleeds out... let it sit overnight withthe car raised , so the oil makes it by gravitiy to the left side. cb the synshros has small holes in wich the oil gotta go tru... i did it and quiet the grind a lot.
EGk3nrock
79
Dec 10, 2007 12:49 PM
Brian-Brian
May 18, 2003 09:31 PM
TypeSH
Jun 9, 2002 12:00 PM
