Timing belt replacement ?????
Old Jul 29, 2009 | 05:47 PM
904d's Avatar
Default Timing belt replacement ?????
Is the job about the same for a V6 as for the 4, like tools needed, time too do the job
parts need. This is for a 2002 V6.
This is what I think I should need to replace. If I'm missing any thing I would like to know.
Thanks for any info.
timing belt
water pump
timing belt adjuster
idler bearing
alt/A/C compressor belt
P/S belt
camshaft oil seals
crank oil seal
2 valve cover gaskets
Old Jul 30, 2009 | 10:12 AM
hondateched's Avatar
Default Re: Timing belt replacement ?????
http://www.denlorstools.com/home/dt1...pful_tips.html
You may need the crankshaft holding tool and the socket/breaker bar for the harmonic balance removal. Here is a link for the tool. You can buy it locally or check on line using the tool no. for suppliers.
Do you have a Haynes manual for the proceedure?
Ed.
Old Jul 30, 2009 | 11:26 AM
904d's Avatar
Ed.
Yes we order the factory shop manual should be here by next Wed. and I can pick up that tool locally. Thanks
hometheaterman
Jun 4, 2010 11:17 AM
The-Kid
Feb 8, 2008 03:47 PM
jimjonez
Mar 19, 2007 05:00 PM
D21X
Aug 21, 2006 04:54 PM
jsyjordan
Jan 14, 2006 10:07 AM
