d16y8 block
Old Jul 29, 2009 | 02:10 PM
byc_cb7's Avatar
Default d16y8 block
will a d16y8 block mate to a d16a6 head with out any problems??
Old Jul 29, 2009 | 02:18 PM
D16SiHatch's Avatar
Default Re: d16y8 block
Yep it will. But you will need to install the a6's oil control jet into the y8 block. Oh and almost forgot. You need to extend the fan switch wiring from the back of the engine over to the switch will be now located on the thermostat house.
Old Jul 29, 2009 | 02:20 PM
TURBOcrx@1.4bar's Avatar
yes sir it will do what d16si said tho. and ull be fine
Old Jul 29, 2009 | 02:39 PM
byc_cb7's Avatar
thanks alot guys wut exactly does the oil control jets look like?
Old Jul 30, 2009 | 10:01 AM
ill try to take a pic for you and post it ive got a few engines apart i just need to find my camera.
Old Jul 30, 2009 | 11:25 AM
BiG ChOr!Zo's Avatar
or vise versa...!!!
http://www.geocities.com/senpai_perf.../a6minime.html
Old Jul 30, 2009 | 11:29 AM
D16SiHatch's Avatar
you'll find it in the block located here..
Old Jul 30, 2009 | 11:45 AM
19REX89's Avatar
can you get that jet from the dealership... because dont they usually get messed up when you pull them out?
Old Jul 30, 2009 | 01:07 PM
i can get it for you if your willing to drive to redlands.
Old Jul 30, 2009 | 03:53 PM
D16SiHatch's Avatar
if i recall i think you can like unscrew them out of the block with a screwdriver. but i dont recall its been some time since i did a mini me swap lol
Old Jul 30, 2009 | 04:09 PM
4drEF's Avatar
Keyboard Humorist
It's usually removed by screwing a screw into it and then pulling on the screw with pliers. It's held in with honda-bond or something.
Justinrobi21
Mar 26, 2015 02:08 AM
jwaggz21
Dec 6, 2012 11:22 AM
B18PwdCivic
Aug 30, 2009 11:29 AM
02spoon
Mar 5, 2008 05:23 PM
civichb95lnd
Dec 11, 2005 05:49 PM
