how can i tell if the MAP, IACV, or TPS is bad? concerning idle issue
Old Jul 29, 2009 | 02:09 PM
1nsoman1ac's Avatar
Default how can i tell if the MAP, IACV, or TPS is bad? concerning idle issue
hello all. just to summarize real quick:
1993 honda civic with 96 ls swap. simple bolt ons. no idea what the dyno is lol.
so my car idles at 1200 rpm. it used to idle at a perfect 500-750 rpm. the throttle screw...the one your not supposed to turn...is completely out...the throttle spinny thing is not resting on it at all.
so heres what i did:
1. unplugged the IACV sensor while car running=no fluctuation in idle. still running at 1200 rpm. doesnt it mean the iacv is bad? then i unplug the TPS and same thing it keeps idling at 1200.
2. i unplug MAP sensor. car dies. i heard this is a good sign.
3. so then i check the voltage to the TPS with key ON (II). voltage reads .33v. so i adjust the screw till it reads.45volts and start the car. idles at 2200 rpm. so im like wtf and readjust it till it idles at 1200 and the screw is completetly out again.
4. i repeat process five times and each time i get a different reading with key turned ON (II). like .45v, .67v, .92v, .33v. etc.
so what is going on? ive driving the car liek this for a month. it runs fine but idles at the 1200 sometimes 1500 if i drive it fast. any ideas?
Old Jul 29, 2009 | 02:25 PM
1nsoman1ac's Avatar
Default Re: how can i tell if the MAP, IACV, or TPS is bad? concerning idle issue
bump
Old Jul 29, 2009 | 02:32 PM
v8killaz's Avatar
any air leaks,
Old Jul 29, 2009 | 05:48 PM
1nsoman1ac's Avatar
not that i know of...how can i check? i recently reran all my vacuum hoses cuz mine were the origional ones and corroded and i had a few silicone ones that i didnt like anymore so yeah. how can i check?
heyitzspikey
Jan 29, 2007 09:19 PM
StreetRacinThug
Jun 19, 2006 12:21 PM
CRX_Control
Dec 30, 2004 11:03 AM
streetlvlhatch
Mar 30, 2004 05:08 PM
civicracer1993
Feb 24, 2003 07:25 PM
