Civic randomly died and isn't getting fuel
I just pulled out onto the hwy and reached about 35mph then car died. I coast to emergency lane. The car cranks but wont start at all. When I turn the key to on position the cel stays on and doesn't go out like normal and I can't hear the fuel pump priming. I've taken the hard line that goes into fuel filter off and when I crank the car nothing comes out?
So far the main relay tests fine (replaced 4yrs ago)
New fuel pump today
ECU fuse is good
ground at thermostat housing is good
I'm getting a solid cel too
What else do I need to check?
New fuel pump today
ECU fuse is good
If I understand it correctly when I tried to pull a code. The cel never flashed it just stayed on. I'll check those fuses. I've haven't checked for spark because I know I'm not getting fuel. Do I need to check for spark anyways? No, I don't have an ecu to swap.
You have CEL code 0. If you also don't have spark together with code 0, then you surely have a problem with power or ground to the ECU or the ECU is bad. You also might test whether the MAP sensor is getting 5 reference volts from the ECU.
It's the YEL/RED wire in the MAP sensor connector that should have 5V when the key is turned to ON(II).
According to the schematics in my manual there is no ground wire in the ecu, unless the unit itself is grounded when bolted down? Is there a way to test the ecu in or out of the car? How do you test whether map sensor has 5 reference volts from ecu? I'll clean the ground on therm. housing.
A23 - BLK
A24 - BLK
A26 - BLK/RED
B2 - BRN/BLK
i had this similar problem recently. it ended up being the 15 amp acc fuse on the under dash fuse box.
its the one by itself and it should say "ACC" on the box diagram right where the red errow is pointing.
also! dont just check your fuse visually only. that was the error o was making. i had checked that same fuse maybe 2, 3 times visually till i decided to check it with a test light. the fuse looked perfect and was not broken but still was not passing power.
No voltage on any wires going to map sensor with ignition on or off. 15 amp acg fuse tested good. I replaced part of the dizzy internals 2 yrs ago trying to diagnose another issue. That should still be good.
Sorry it took so long to respond back I've been at work ALL day. My brother picked up a used ecu out of a dx today so I swapped it out tonight and the car started right up.
It seems like I've replaced just about everything on this car at least once. I hope its good for awhile...280,XXX and counting!
I believe it was the ignition coil that I replaced.
Thanks for everyone's input.
DumpedSi
13
Nov 29, 2006 09:17 PM
PrestonCRX
12
May 12, 2006 02:00 PM
