Exhaust GASKETS?
Old Jul 29, 2009 | 09:11 AM
JDM Projects's Avatar
Default Exhaust GASKETS?
I bought this Thermal R&d CL catback system for the CRX. This guy didn't have the bolts, nuts, or the gaskets for the catback. I can get the bolts from any hardware store, but what about the gaskets. I will need 2 gaskets for the catback. The piping is 2.25inches. Where can i be able to get this size gasket or any other suggestions?
Old Jul 29, 2009 | 03:01 PM
johnnyonth3spot's Avatar
Default Re: Exhaust GASKETS?
this is the **** i took a pic of the part number
I use this stuff on my header this is the only stuff that wouldnt burn and break apart after a few days. It has a metal mesh layer between the gasket material its just a bit hard to cut use metal snips I had to get this stuff at napa, its the only place I could find it
Old Aug 4, 2009 | 07:18 AM
What is it called exactly? i need to cut it out?
Old Aug 4, 2009 | 08:33 AM
jonnyt1130's Avatar
im pretty sure you can get them at your local advanced auto or autozone (gasket)
Old Aug 4, 2009 | 02:05 PM
dude i posted a pic with the name and part number on it PRO-RAMIC part number 2499 try auto zone or advanced but I had no luck at my locals execpt for napa
Old Aug 4, 2009 | 03:15 PM
EL Vap133's Avatar
Go to a junkyard and pull them off some other car.
turbogsr181
Apr 7, 2014 03:51 PM
Bleakened
Oct 21, 2013 07:29 AM
autosport7
Welding / Fabrication
Apr 20, 2007 12:32 AM
the soL that could
22
Feb 2, 2006 07:08 PM
LaOstha
Sep 28, 2005 02:37 PM
