how do i clock my turbo when its all rusted?
Old Aug 23, 2002 | 09:46 PM
batboyvaj's Avatar
Default how do i clock my turbo when its all rusted?
i getting my setup all ready and the turbo i got is kinda rusted together on the exh. housing part. i can clock the comp. part easy but the iron stuff is rusted on. how did some of you guys clock your rusted stuff. its a t3 off a svo
Old Aug 23, 2002 | 10:02 PM
Ri5e's Avatar
Default Re: how do i clock my turbo when its all rusted? (batboyvaj)
Spray Wd-40 ont he bolts and try to use a big wrench. If that doesn't work, heat up the turbo with a torch and try again. After the bolts are loosened, try rotating it. If it doesn't rotate, spray Wd-40 and use a rubber mallet and bang on it. Eventually it'll break loose.
Old Aug 23, 2002 | 10:06 PM
batboyvaj's Avatar
Default Re: how do i clock my turbo when its all rusted? (BG Boost)
i got all the bolts out...its just the housing thats all rusted up
Old Aug 23, 2002 | 10:17 PM
paulzy's Avatar
bang it with a rubber mallot
Old Aug 23, 2002 | 10:20 PM
Ri5e's Avatar
Default Re: how do i clock my turbo when its all rusted? (paul_vang)
Bang the **** out of it and it should break loose.
Old Aug 23, 2002 | 10:24 PM
batboyvaj's Avatar
i'll try that tomm....
patrick4588
Jun 29, 2007 09:33 PM
zexifiedlude
Nov 27, 2005 07:48 PM
pro547
Jun 20, 2005 12:54 PM
B18C-RnVA
Sep 15, 2002 06:59 PM
HondaCutter
Sep 6, 2002 12:28 PM
