Transmission & Drivetrain Gearboxes, Differentials, Clutches
loose clutch pedal/ cannot shift into gear
Old Jul 29, 2009 | 03:09 AM
AdRoz's Avatar
Post loose clutch pedal/ cannot shift into gear
about 30 mins ago i got in my car and noticed that the clutch pedal was really loose like as if there was no cable connected. Im thinking maybe the cable broke or is stretched. And because of the clutch i cant shift into gear, therefore my car is not able to go anywhere. If anyone has experienced this before or know whats the problem with my clutch please inform me with what i can do or how i can fix this problem. Im also concerned about towing my car to the shop, was wondering if that will be necessary... sigh* such bad luck
Old Jul 29, 2009 | 08:35 PM
stevenDAtegra's Avatar
Default Re: loose clutch pedal/ cannot shift into gear
Have you tried adjusting the cable where it goes into the lever? It can be tightened down more and you can also adjust it with the pedal.
Old Jul 29, 2009 | 08:55 PM
90sedan's Avatar
What kind of vehicle?
First check the cable and its free play at the transmission. It should have about 1/4" free play, otherwise adjust accordingly. Also have another person inspect the cable's movement at the transmission while you step on and off the pedal. Next check underneath the dash and inspect the clutch pedal. Make sure the clutch pedal hasn't begun to break off from the pedal assembly and that the cable itself is still attached to it.
Old Jul 29, 2009 | 10:45 PM
I forgot to ask, are you able to shift into the gears while the car is off?
Old Aug 7, 2009 | 10:57 AM
matthoward77's Avatar
New User
I am having the same problem, and i can shift into gear while the car is off... what does this mean?
Old Aug 12, 2009 | 09:54 AM
Clerique's Avatar
Clutch is not disengaging for some reason.
1) Either one of your clutch cylinders could be bad or needs bleeding.
2) Release bearing could be destroyed.
3) Piece of your clutch disc could have broken off and lodged between the pressure plate fingers causing it not to function properly.
4) You need a new pressure plate
Old Aug 18, 2009 | 12:54 PM
mrbh22's Avatar
or the clutch fork that goes from the slave cylinder to the throw out bearing had somehow broken. like mine did. i had the same problem. and never knew it until i took the tranny off
Old Aug 19, 2009 | 08:37 PM
teggi's Avatar
my tranny is doing something similar
when i first start the car it shifts nice and easy but when the engine warms up it wont shift as easy and the revers grinds a lot
idk wats wrong wit it
RyanIrwin90CRX
Nov 14, 2013 06:44 AM
G2_Fella
11
Jul 6, 2005 03:08 PM
rapture
Dec 17, 2004 08:00 AM
ek_99_SiR
10
Apr 2, 2004 01:28 PM
veggiemaster
Dec 15, 2003 03:15 PM
