d16y7 into 93 dx
i did some searching and have a few questions.
all i would need to make the motor run is swap over my d15 dizzy, injectors and alternator? also, will the original drivers side mount bolt onto the d16 stud assembly?
What ecu are you planning to run? but yes you can switch over your alternator, injectors and dizzy since they are obd1 whereas your d16y7 is obd2. The studs, are you referring to the engine bracket? I think you might have to as well as your rear engine bracket or T or L bracket mount with your eg one
im gonna run the stock ecu. its gonna be mated to the auto trans currently in the car.
and yah, im referring to the engine bracket (the one with the 2 studs on them). so what parts do i use for the mounts. just reuse all the EG parts?
AccordVT
Feb 20, 2012 07:17 PM
fabe85
Jun 18, 2007 09:32 PM
JDM CTR EK
10
Jun 16, 2004 04:02 PM
