installed camber kit tire squeels when turn to the left
just installed a camber kit (control arms) on a eg and now when i turn left the tire squeels, ive never had this happen before. seems more like a toe issue but it didnt do it before the camber kit install. I kinda bent up one of the little bars that you got to swap over from the stock uca that wouldnt cause it would it?
will the bar that i bent (the one that connects the uca to the frame) cause the tire to squeel like this or do i just need to get an alignment now? the bar is all mounted up correct.
did u do the camber kit urself? cuz i just bought one for my del sol and i wanna see if i can pput it together myself. do u know what tools i will need and is it hard work?
yeah, get an alignment. theyll probably tell you 100 bux give or take since its been "modified" and make sure you give them the adjustments you want, alot of shops are retarded and only do OE type stuff
1) put stock UCA's back on
2) get alignment
3) ??????????
4) Profit!
https://honda-tech.com/forums/suspension-brakes-54/no-you-do-not-need-camber-kits-2614449/
2) get alignment
3) ??????????
4) Profit!
