Honda S2000 Honda S2000
looking for a DYI to pull out a s2000 motor
Old Jul 28, 2009 | 04:16 PM
djpepsi's Avatar
Default looking for a DYI to pull out a s2000 motor
hi guys does anyone have a DIY for pulling out a s2k swap thanks
Old Jul 28, 2009 | 06:40 PM
eclypzex's Avatar
Default Re: looking for a DYI to pull out a s2000 motor
idk what you mean by swap? what motor are you putting in?
afaik theres very few ways to PULL a motor. if you need to ask, you really shouldnt be pulling it. let someone else do it.
Old Jul 28, 2009 | 06:57 PM
dagle's Avatar
get the chassis as high as you can (like 3feet up), take off the bolts holding the motor mounts in. you should probably make sure theres support under the motor though so ber careful. after that, just drain fluids, disconnect all coolant lines, harnesses, then unbolt the tranny and and that bitch will drop out
Old Jul 29, 2009 | 05:36 AM
White Smoke's Avatar
i my honda
Global Mod
Try a search next time...
http://www.garage411.com/EngineRemovalS2k
93hondaboy
Dec 1, 2008 04:28 PM
jdmludeaz
Jun 28, 2007 09:17 AM
jansenrw
Jul 7, 2003 05:06 PM
civicvtec3
May 28, 2003 03:50 PM
EtotheG
Mar 14, 2003 01:15 AM
