bent valves
Old Jul 28, 2009 | 03:30 PM
turbohatch96y7's Avatar
Default bent valves
I got alot of bent valves on my head irs a gsr head with about inly two valves that arent bent. Can i just buy new valves and call it a day or do i need more done to the head.
Some valves are really bent as in a big gap from where there supposed to sit and some are just alittle off
Old Jul 28, 2009 | 05:46 PM
conekiller123's Avatar
Default Re: bent valves
You need to remove cylinder head Inspect all valve train parts of damage, inspect the combustion chamber, valve guides, valve seats, etc for damage. Make sure all parts/cylinder head is still within oem specifications
-Remember you cannot always tell if the valve is bent or streched by the common eye
All new valves would be recomended due to the low cost and a safe state of mind, and the possibility of your 2 (Straight valves) might be infact bent or streched. They each need to be seated properly and checked for a complete seal and properly adjusted with reassembly of cylinder head
Good luck
Old Jul 28, 2009 | 06:50 PM
yeah i removed the head already okay so alot more parts could be damaged so should i just get oem valves or upgraded ones
Old Jul 28, 2009 | 07:37 PM
up
Old Jul 28, 2009 | 08:45 PM
hhjfgg
Old Jul 28, 2009 | 09:07 PM
D16SohcVtec's Avatar
You might as well just rebuild the head with new valve seals etc since the head is going to come off. You need to decide if you are going to go with oversized or stock sized valves. You need to take the head to a machine shop so they recut the valve seats.
Old Jul 31, 2009 | 07:42 PM
so if i just get stock valves it still has to be recut is there a good site to get new valve seals.and all the stuff to make it like a fresh rebuild
Old Jul 31, 2009 | 09:38 PM
thumper64's Avatar
OEM seals are good, or there are Viton ones made by Ferrea that I think I heard are good.
ITR valves would be good, or any good aftermarket brand.
Old Jul 31, 2009 | 09:53 PM
chinochanginc's Avatar
take it to a machine shop.. have em take it apart and hot tank it.. then change all the valves, and valve seals.. then have em Lap the valves
Old Aug 1, 2009 | 07:04 AM
92ehatch's Avatar
make them grind the valve seat as well.
the valves in my old head were slightly bent and made the valve seats an oblong shape, basically trashed them.
i agree with everyone who says rebuild the head, its easy to do and well worth it.
Old Aug 1, 2009 | 12:16 PM
okay so i can take it to pretty much any head shop since this is routine stuff..
Old Aug 1, 2009 | 12:17 PM
what do u mean have them lap the valves?
Old Aug 1, 2009 | 12:32 PM
92ehatch's Avatar
just take it to a machine shop, they know what to do with it
Old Aug 1, 2009 | 12:41 PM
but would it be better to take it with the parts or just drop it off
Old Aug 1, 2009 | 02:21 PM
92ehatch's Avatar
it is cheaper if you take it apart and all the valves out
and then tell them you will put it back together yourself
i did that, i got 2 heads checked, all my valves and seats ground and head leveled and he only charged me 25 bucks.
he got to keep the second head tho (it was pretty much trashed) guides were shot, seats were shot.
of course, i was wearing my honda uniform, he probably gave me honda dealership discount
Old Aug 1, 2009 | 06:35 PM
okay i think ill do that then thanks for the help
SirRevvs
Oct 14, 2010 10:32 AM
HondaKing90
19
Feb 15, 2010 04:38 PM
HondaKing90
Engine Management and Tuning
Feb 13, 2010 09:09 AM
god.loves.ugly
Dec 20, 2006 11:56 PM
jdmjeff
Dec 21, 2005 02:18 PM
