B18B intake manifold on b20
Old Jul 28, 2009 | 02:27 PM
.:urbandc2:.'s Avatar
Default B18B intake manifold on b20
So my main question is, am i required to torque down the the nuts and bolts to the intake manifold, or can i just "hand-tighten" them?..
thanks.
Old Jul 28, 2009 | 03:17 PM
KWayRacing's Avatar
Default Re: B18B intake manifold on b20
Although there is a spec and a way to torque every nut and bolt on your car the nuts and bolts to hold on the IM are pretty tight spots to get to. I start all by hand then tighten from the center to the outside similar to the head bolt pattern. Then I douublr check them all for tightness. To answer your ? simply just tighten them down. As I am sure these are not the first nuts/ bolts to tighten use your good judgement and just down tighten them until they break.
MJOLNIRvTEC
Aug 18, 2008 07:59 PM
rdssk8rcs1
Jan 15, 2008 09:41 PM
descartesfool
Sep 24, 2007 05:08 PM
descartesfool
Sep 22, 2007 08:55 AM
