Transmission & Drivetrain Gearboxes, Differentials, Clutches
We Need this to be sticky'd
Old Jul 28, 2009 | 10:58 AM
vtechjunkie's Avatar
Default We Need this to be sticky'd
What are the torque spec for the pressure plate bolts to the flywheel? i need this info from ya'll as I have tried my Haynes manual but all it says anything about are the drive-plate bolts. Help please.
Old Jul 28, 2009 | 11:32 AM
cpl rampage's Avatar
Default Re: We Need this to be sticky'd
its 19 ft lbs for d-series but you didn't tell us what car you have, i would only assume it is the same for b series since they use the same bolts.
Old Jul 28, 2009 | 11:39 AM
K. I went to 30lbs. Nothing broke, thank god!
Old Jul 28, 2009 | 08:38 PM
Honda Bull's Avatar
No need for them to be that tight though. As long as everything is even, they won't back out.
BTW, the Hayne's will have the pressure plate bolt torque specs. Look harder.
Old Jul 28, 2009 | 10:18 PM
I looked. It said it was on 2B-16, that said to refer to 2A-14. Specs are in the front of each chapter and the specs for both are the same. 54lbs.
Old Jul 29, 2009 | 12:17 PM
KRX 7056's Avatar
According to the 94-95 Acura Integra service manual:
Flywheel: 76 lbs
Pressure Plate: 19 lbs
Old Jul 29, 2009 | 01:40 PM
Cool thanks!
aznej2
Oct 4, 2014 01:35 PM
snzh22
Jun 13, 2008 01:06 AM
jweeks
Apr 24, 2007 05:26 PM
Zornig
Jun 26, 2004 10:19 AM
im_poor
May 7, 2003 09:07 AM
