Transmission & Drivetrain Gearboxes, Differentials, Clutches
Are final drives interchangeable between the VX and HF transmission?
Old Jul 28, 2009 | 05:52 AM
greasemonkee's Avatar
Default Are final drives interchangeable between the VX and HF transmission?
Seems to be difficult to come across an answer to this. Is it possible to put a CRX HF final drive into a VX tranny? IS it a direct fit?
Thanks for anyone with info.
Old Jul 28, 2009 | 07:19 AM
David @ Synchrotech's Avatar
Default Re: Are final drives interchangeable between the VX and HF transmission?
The Ring gear is the same but the countershafts are different. The 88-91 HF C/S is shorter than the 92-95 VX and has a shorter bearing section for the 1st gear.
Old Jul 28, 2009 | 05:15 PM
Thanks for the help.
Old Jul 28, 2009 | 08:13 PM
Mista Bone's Avatar
D Tranny Guru
same 3.250 ratio, what are you looking for?
Old Jul 28, 2009 | 08:21 PM
I thought the HF was a 2.95 final? Have a car with an extremely low Cd and need something taller than the 3.25 vx. I have a feeling, there is no easy solution.
Old Jul 30, 2009 | 10:19 PM
Mista Bone's Avatar
D Tranny Guru
HF was 2.95 for 88, 3.25 for 89-91
What tranny do you have, cable or hydro???
What FD are you looking for?
I likely have the cheap parts.
Old Jul 31, 2009 | 05:30 AM
I have a CX hydro. The goal was to bring 5th gear down to 2000-2100 @ 70 mph. The car has a super low drag coefficient.
Old Jul 31, 2009 | 08:57 PM
Mista Bone's Avatar
D Tranny Guru
Why bog the motor?
93 DX HB, 121 whp, 53 mpg, stock DX tranny.
Happiest at 3000 rpm.
Drop the rear bumper cover.
Old Jul 31, 2009 | 10:11 PM
As I stated before, this is a civic with an ultra low drag coefficient. The Cd is .17, stock is .34. The body has been heavily modified and uses very little hp to maintain a 70-80 mph cruise. The car currently has achieved a 91 hwy mpg and average between daily city and hwy regular driving is 70 mpg.
I'm currently preparing a vtec-e and would like a taller gear so it doesn't drop out of leanburn. I may be tuning this thing to get around that if there is no affordable way to raise the gear. Thanks
Old Jul 31, 2009 | 10:19 PM
I had a customer recently whom I installed a HF 2.95 tranny in. He went from a consistent 44 mpg to 51, just with a tranny swap. This was a 91 hatch. He apparently know how to keep it loaded under closed loop in all conditions.
Old Aug 1, 2009 | 05:23 PM
Mista Bone's Avatar
D Tranny Guru
vacuum gauge is a big help.
My D15B7 was tuned lean + timing above 10" of vac, below that it went back to near stock maps.
It had a bad habit of sucking up to trucks in a draft, I mean lift off the gas, which leans out and adds more timing and it would keep pulling, you had to time the slingshot around the truck.
Old Aug 1, 2009 | 05:50 PM
Ahhh, clever tactics.
I tune my cars roughly the same, normally cross over stoich around 10-11 in/hg, the exception being my personal car that doesn't appreciate very lean afr's. Somehow, with the ITR gearbox, it still manages 34-35 on the hwy.
Old Aug 2, 2009 | 11:51 PM
Mista Bone's Avatar
D Tranny Guru
Wait a ****ing minute.............
you are talking about SOHC CX/VX/HF gearboxs and now running a ITR box?
DUDE, WTF??
Old Aug 3, 2009 | 06:05 AM
The original question I had was regarding a CX/VX gearbox, a customers vehicle, which we have established there is nothing we can do to change.
My personal vehicle's gearbox is an ITR, different car, and yes the 5th gear sucks in it also.
Thanks for your help.
CM11NACO
Apr 11, 2012 06:49 PM
rice is nice
Jul 21, 2008 07:49 AM
Voodooboy520
Southeast (Sales)
10
Jul 13, 2006 12:55 PM
md88hfcrx
24
Nov 24, 2005 11:07 AM
niceguy12
32
Mar 17, 2005 11:39 PM
