oil on tps sensor???
I'm running a peakboost h22a4 ... I got a CEL for tps sensor the other night, so i pulled it off to check everything out and the thing literally had oil dripping off the end! What's up with that?
I havne't had a chance to check anything out better yet b/c a couple miles down the road when it was gettign warmed back up my trailing arm gave way where the lca connects.. getting it back wednesday so we will see then
O really? I have been noticing an increased amount of blu-ish smoke at idle and low rpm's... When I get my car back I will get a chance to pull my spark plugs and do a compression test hoping it is nothing internal!
I would check your charge piping first before looking at the health of the internals. There is really only one way to get oil on the throttle plate/TPS. Of course it doesn't hurt to check the compression/leakdown every now and again.
