tailights and dash dont work!!!!NEED HELP
Old Jul 27, 2009 | 03:48 PM
kaka10's Avatar
Default tailights and dash dont work!!!!NEED HELP
Hi guys im new here at this forum just bought a 98 prelude....but have a problem with it...the taillights and my corners,and dash dont work...so i cant drive the car at night...however the car came with an alarm system every time i alarm or disalarm the car the corners,dash and tailights do work...but when ever i turn them on only my headlights work
i checked the fuses and all are ok. please guys need your help on this.thanks
Old Jul 27, 2009 | 05:35 PM
Lovemy99Lude's Avatar
Default Re: tailights and dash dont work!!!!NEED HELP
I had this same problem about two weeks ago after installing my new cd deck. It should be just your tailight fuse under neath the driver's side dash; 15a fuse.
Old Jul 27, 2009 | 05:37 PM
kaka10's Avatar
yea i checked them all and there fine..like i said they blink with the alarm..but not when i turn them on with the headlight swicht
Old Jul 27, 2009 | 05:50 PM
kaka10's Avatar
is there a relay for the lights???
Old Jul 29, 2009 | 10:51 AM
kaka10's Avatar
help plsss
Old Jul 29, 2009 | 11:11 AM
ludeking1007's Avatar
sounds like your alarm was put in wrong or you have a short but you need to go back and look at all the fuses
Old Jul 29, 2009 | 11:16 AM
vinuneuro's Avatar
This is exactly right. Fuse # 10 under the dash.
Old Jul 29, 2009 | 11:17 AM
kaka10's Avatar
yea...but shouldnt they work at all...beacuse like i said when i alarm or disarm they do blink...dash,tailights and corners
Old Jul 29, 2009 | 11:49 AM
pinoy.solsi's Avatar
lol i have the same problem....
when i use my remote to start the car the dash light is on
but when i put my keys in and step on the brake the dash light goes off.
my headlight and my taillight is fine. it jst the dash.
Old Jul 29, 2009 | 11:54 AM
BlueLude94's Avatar
when your alarm is wired to your dash light/taillights and it is arm/dearm the alarm module send a 12v signal to the lights bypassing the blown fuse which is closer to the battery. I say double check your fuses. If thaty doesn't work time to break out the multi-meter and start chasing sparks
Old Jul 29, 2009 | 11:23 PM
kkk ima change my fuse tmrw and ill come back here n tell you if it works lol.
Old Jul 30, 2009 | 03:04 PM
i checked all the 15a fuse under the dash i even checked underthe hood jst incase.
n there all fine...
anyother solution to this problem?
Old Jul 30, 2009 | 03:16 PM
TheCivicMafia's Avatar
I had this problem long ago when i have put in my Halos on a civic, There was a short in the headlights, making the tail lights and dash light fuse to blow and not work.
Old Jul 30, 2009 | 03:31 PM
kkkkkkkkkkkkkkkkk
i got mine fixed! i found the blown fuse and its not 15a its a 10
kaka10 heres a picture
of your fuse box
its the 10 fuse beside the starter signal hope i helped you =D
Dropmy Si
Honda Civic (2006 - 2015)
Oct 2, 2008 10:31 AM
WrongBeach
May 4, 2007 02:38 PM
Josky4ya
Oct 21, 2005 09:57 PM
chameleon
Dec 15, 2002 09:37 PM
