Need some help 95 db8 rhd
Old Jul 27, 2009 | 02:27 PM
red02s2k's Avatar
Default Need some help 95 db8 rhd
I have a 95 4 door teg just did a rhd/jdm conversion to the car. When we finished wiring everything up and plugged the battery in the defrost and right turn signal is on even with the car been off but the right turn signal is not lit up. If this makes a difference the lights work the windows, locks and tails all work just fine. If anyone has and idea or knows someone that has had this prob please let me know.
Old Jul 28, 2009 | 06:30 AM
red02s2k's Avatar
Default Re: Need some help 95 db8 rhd
anything?
Old Jul 28, 2009 | 08:36 AM
dephtone's Avatar
I mean this sounds obvious but sounds like you have a constant power wire that is fused with the turn signal and/or defrost, plug in the battery so they come on, start at the fuse box and work your way to the turn signal. Something may have gotten crossed under the dash.
Old Jul 28, 2009 | 09:04 AM
red02s2k's Avatar
I'll look into that more maybe i just missed it.
Thanks
Old Jul 28, 2009 | 09:08 AM
dephtone's Avatar
Pop out the fuse for the turn signal and see if you still have power to them. That should tell you that there is power somewhere still.
I have a semi similar thing with my fan, it's hooked on a switch but when i plug the battery in, the fan turns on no matter if the switch is on or off, I have to pop the fuse out to shut it off.
Old Jul 29, 2009 | 08:08 AM
red02s2k's Avatar
lol it was such an easy fix I had pluged one of the under dash clips into the wrong clips
Thanks for the help
Old Jul 29, 2009 | 10:17 AM
dephtone's Avatar
Awesome glad you got it figured out.
tom2865
Jun 8, 2015 12:35 PM
patpat
Mar 15, 2015 11:56 AM
civiceagle2
39
Feb 21, 2012 08:37 PM
j_kevin_ca
Jun 25, 2007 11:00 AM
blackdude
Mar 20, 2005 07:33 PM
