time for some REAL tech
Old Jul 27, 2009 | 10:58 AM
sh!ft's Avatar
Who the fack changed my title?!
Default time for some REAL tech
ok so we all(or most of the people here have seen) know i blew my motor last nite by throwing a rod. any ways ive been doing some research and have come to this conclousion, the 88-89 d16a1 pistons with integra ls rods going into a d15b7 block running a d16z6 head using the z6 accessories(water pump etc) mated with a y8 head gasket will give me the best outcome as far as compression and power.
who can prove me wrong?
Old Jul 27, 2009 | 12:26 PM
jhammond_82's Avatar
Reject Papi
Default Re: time for some REAL tech
me!! ls block, pr3 pistons, pr4 rods, pr4 head, = 11:8.1 . lol, anyway, that setup will work, but the d15 block might not clear the ls rods. i thought the d16 blocks were the only ones that would clear? i'm not sure. you might however be able to get the block machined so the rods clear. but, it might be too much money to do that.
Old Jul 27, 2009 | 12:49 PM
sh!ft's Avatar
hlaf the stuff im doing machingin wise is almost free so im not worried about that
Old Jul 27, 2009 | 03:43 PM
hatch_kidb18b1's Avatar
Why not just use new d15 rods with zc pistons y8 head and headgasket and be running 12 something to 1 compression
Old Jul 27, 2009 | 06:59 PM
Reject Papi
man, idk, thats pretty high compression if you ask me. you'll need to use a high octane fuel for that kind of compression. do a vitara build and boost it.
Old Jul 27, 2009 | 07:04 PM
Well you do have a point but I'm running almost the same setup but more compression and still on pump gas runs great just make sure you get a good tune
Old Jul 28, 2009 | 07:21 AM
sh!ft's Avatar
edit: so instead of using the 88-89 pistons im going to just use the a6 and get 11 something to 1 and be able to run regular fuel and stay safe/streetable
BUT, i am going to go oversized. any one ever done this build before using oversized pistons? the block i have selected already had a block cylinder guard installed.
Old Jul 28, 2009 | 07:33 AM
radex7's Avatar
Well, I am in the process... B7 block bored to 76mm, A6 head, Y8 cam gear (I think), it is just taking me forever...
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/engine-mismatch-2406761/
Several other guys, if not here then on D-series have done this combo with some impressive results for both performance and efficiency, and since waaaaaaay more knowledgeable then me - I am just following their footsteps.
Old Jul 28, 2009 | 07:39 AM
8VEYBEYB's Avatar
what pistons are you ^^ using?
Old Jul 28, 2009 | 08:16 AM
dephtone's Avatar
If you have a REALLY good tuner in your area, I'd run bone stock z6 with P29/PM7 (d16a1 pistons or DOHC ZC) will net you ~12.05:1 compression.
Some say ~12.5:1 compression is a safe bet with 93 octane and a good tune.
Also LS rods are the same length as d16/d17/d15b/z1
Old Jul 28, 2009 | 09:08 AM
sh!ft's Avatar
so would or wouldnt i have to shot peen them?? im already gonna take the head/block/flywheel to the shop for balancing/cleaning.
Old Jul 28, 2009 | 09:10 AM
dephtone's Avatar
stock z6 rods have been proven to 300+ whp, Full-Race had their boosted z6 running 400 whp with just arp head studs.
If you can get it done for within your budget then you might as well do it while the motors apart for the extra peace of mind.
Old Jul 28, 2009 | 09:27 AM
sh!ft's Avatar
well heres the thing, one of the guys at my shop owes me a favor or 2 so i figured since i already will be picking up the block, tearing it apart, and most likely taking the head apart, why not take it all the way down to the bare and rebuild it the right way? i was pissed at 1st about the motor blowing(and kinda felt cool when i saw the motor blow) but now im actually excited about doing this. this gives me more incintive to paint my engine bay as well while im doing this.
i think i will make a video and take pictures of the build as we go. hopefully i will be done in about a weeks time or so. not bad for a random part up with gewt results LOL!
Old Jul 28, 2009 | 09:56 AM
dephtone's Avatar
What happened to the other motor? I read that you blew it. Did you hook up VTEC to a switch like you were saying in one of your posts? Either way, hope this build goes good for you.
Old Jul 28, 2009 | 05:35 PM
sh!ft's Avatar
it was hooked up but the cam seal went out, thus all the oil leaked out and boom! rod through block and dent in hood
Old Jul 28, 2009 | 06:47 PM
n3h3bkau's Avatar
Okay... lets start at the first problem...
LS rods and a D15 crankshaft.
1. LS crank journal - 48mm
2. D15 Crankshaft - 45mm
(Also don't forget approx 0.022" will need to be taken off both sides of the crank end of the LS rods to actually fit)
LS Rods and D16 pistons (excluding 98-00 GX Pistons)
1. LS Piston journal - 21mm
2. Typical D16 piston journal - 19mm
That's just a couple quick issues with your rod choice.
If I was just making something for the fun of it I'd do a little stroker build...
D17 Crankshaft (depending you might have to machine the snout to fit your crank pully)
D17 Oil Pump
LS Rods (sides shaved .022" each)
PDN 98-00 GX Pistons (accommodates for the longer stroke and are domed)
Z6 Block
Z6 Head
Old Jul 28, 2009 | 07:03 PM
Ahknodd's Avatar
^^I've heard that set up is bitchin'. Need a lot of machine work, so that might be a route you should go.
DAinCHI
Jul 11, 2009 08:43 AM
alexg103
Feb 15, 2009 01:24 AM
agp1183
Jan 23, 2006 01:35 PM
93FastLs
Jun 30, 2005 01:57 PM
Hybrid
Oct 7, 2002 04:43 PM
