LS Rods in Z6 block
Old Oct 6, 2002 | 05:22 PM
Hybrid's Avatar
Default LS Rods in Z6 block
I am going to put LS rods into my Z6 block as a cheaper alternative to Eagle or crower rods.
What should I be looking for, block model etc or will they all work, have same measurements/thickness.
Old Oct 6, 2002 | 05:59 PM
Jared's Avatar
Default Re: LS Rods in Z6 block (Hybrid)
Any B18A, B18B, B20B, or B20Z will work for what you're doing.
Old Oct 7, 2002 | 03:49 PM
Hybrid's Avatar
Default Re: LS Rods in Z6 block (Jared)
Right on man thanks alot.
Guess I'm looking, any sellers?
Old Oct 7, 2002 | 03:57 PM
ion_four's Avatar
You might want to consider using b16 rods (I think) and supra pistons...someone was selling them on here, but for a little much, me thinks. In anycase, he's boosting 14-18psi daily and went up to 24psi for a race, if I recall. pretty sweet. might as well do something about the pistons if you haven't already and it's going to be apart...
Old Oct 7, 2002 | 04:19 PM
inspyral's Avatar
Default Re: LS Rods in Z6 block (ion_four)
https://honda-tech.com/zerothread?id=267641
Old Oct 7, 2002 | 04:43 PM
turbo sol's Avatar
Default Re: LS Rods in Z6 block (inspyral)
that great to use b16/supra set up if you can boost that much, but for people like me with a greddy setup 12-14 should be the max psi you use. the ls rods will be fine for that esp with this guys 8.? : 1 arias pistons
check out this post
https://honda-tech.com/zerothread?id=260806
JDMeg95
Nov 7, 2007 07:03 PM
HondaEJ7
18
Oct 11, 2007 02:41 PM
94teg2.0
Mar 14, 2007 09:20 PM
mr.si1
Oct 18, 2006 10:31 AM
RacerBoy
Jan 3, 2003 12:04 PM
