Parts Problem with B16
Old Jul 27, 2009 | 04:22 AM
BuiltCivic99's Avatar
Default Parts Problem with B16
i have a b16a in my car not b16a1 the only place b16a came from are Sir's and the integra rsi...but heres my problem are parts for b series all universal except for the OBD parts? if not what parts from what kind of car do i get my AM parts and OEM parts from
Old Jul 27, 2009 | 05:19 AM
robbys89's Avatar
Default Re: Parts Problem with B16
yes all are the same apart from OBD connections depending on year, stick to the 92-95 parts witch is what im guessing the engine is, i posted up somthing like this before and thats what i was told..
Old Jul 27, 2009 | 06:26 AM
B16acoupe94's Avatar
I have a question i did a b16 swap in my 94 coupe everything went fine but when i went to go drive it, it sounds like the passenger side axle is binding up when turning. I used the axles that came with the motor and trans. By looking at the axle it appears that it is to long. It looks like the axle is bottomed out in the housing. What axles should i use?
Old Jul 27, 2009 | 06:58 AM
The OEM axels the full swap that u got came with the wrong axels probably or you didnt install it correctly.
Old Jul 27, 2009 | 07:19 AM
robbys89's Avatar
yeah be sure you connected everything back up right, i got my b16 engine,trany and axles from a 93 del sol and everything went perfect, and they went into my 94 civic coupe
Old Jul 28, 2009 | 06:28 AM
I also have a 94 delsol with a b16 I'm guna swap in those axles and see what happens
HA05
Transmission & Drivetrain
May 25, 2015 06:38 AM
wrenchy
Dec 7, 2009 09:36 AM
dohc_87hatch
Nov 12, 2009 10:01 AM
RSXcess
Oct 16, 2007 07:22 AM
