Rear Sway Bar question
So I have a 98 EK Sedan, and it's DX model. As far as I am concerned, I do not think I have a stock sway bar.
I wanted to install one in (Suspension Techniques) and I was told that I would have to remove my stock LCAs and throw in new ones or aftermarket ones in order to get my rear sway installed. Can anybody tell me if I can just bolt on the rear sway without any additional work? From what I could see, there are holes in my stock LCA where I can just bolt the rear sway directly on, with no problems. Idk, what do you guys think?
WRONG! You only need to change out the lca if you are adding a FRONT sway. The rear LCA are the same on all models of the 96-00 and all can accept sway bars. That being said, to add the 13mm SI or 14mm GSR sway, you will need the stock 99-00 SI end links, or you could buy some aftermarket ones, but they need to be 99-00 SI style.
amej8
Jun 17, 2008 06:16 AM
Amuse9
Dec 30, 2002 12:48 PM
