slicks and all motor
what would be the best size slick to run?
car is all motor crx stroker with est 250whp 2000 civic si tranny with a quaife and gator stage 2 axles.. full race traction bars.
currently have 22x8x13 on weld wheels
thanks.. i was assuming the 22" slicks were a bit small for the amount of tq the stroker puts out..
apparently i read that the 2000 si tranny has a 4.26 final drive.. not sure how that will effect things..
2000 SI has a 4.4 final drive. That is a misprint in the manual or wherever you read it. Count the teeth on the ring gear and you should have 66 teeth, not 64.
thanks for the imput.. ive searched for a good thread with info about slicks but it seems i cannot find much.. i have some questions i think would be useful info if answered.
how to pick the correct slick for and application?
at what horsepower level should you go to a larger slick?
my thought was you would take hp and gear ratio numbers to figure out the proper size??
as for my question i think it was answered as 2 people whom have fast all motor cars have given the same answer.. i guess im just wondering how you came to that size?
The two guys with fast cars that posted don't have exactly the same setup as you, so their slick size may not be best for you to use. 250 WHP on a dynojet in a street CRX on slicks should get you around 11.20-11.40 range if everything is right.
how much does your car weigh? what are your current 60's looking like? what ET and trap does your car run with its current setup?
eddiecut
12
Jun 26, 2003 10:46 AM
