SEARCHED! Need these questions answered!
Old Jul 26, 2009 | 10:22 PM
vtechjunkie's Avatar
Default SEARCHED! Need these questions answered!
I have Mines performance manifold (w/ external wg) and a downpipe that I had custom made. The turbo is a 50trim 48a/r turbo and the motor has springs retainers, rods pistons, and all the ARP bolts. My questions are:
1. What are the draw-backs of heat wrapping the manifold? Cracking, loss of longevity?
2. What kind of IAT difference will it make?
3. How does that translate to HP?
Old Jul 27, 2009 | 01:28 PM
NonovUrbizniz's Avatar
Loved
Default Re: SEARCHED! Need these questions answered!
1. It can trap moisture and cause rusting (although you can use sealants/coatings to prevent this)
2. Not sure but definately not a HUGE difference... it's main benifit is lowering underhood temps and keeping heat in the turbo/DP to keep exhaust gases flowing well.
3. it doesn't. You may spool a little faster the IAT may drop a little but it's not like you put it on and gain 20hp or anything like that.
Old Jul 27, 2009 | 01:43 PM
srmofo's Avatar
I dont know how much I believe the trapping moisture thing.....turbo pipes get hot enough to evaporate any moisture that might be in the wrap after a good soaking from a puddle.....maybe if the car sits alot in a damper climate but for the most part I just dont believe it to be an issue.....Manifolds go through alot of abuse just from the heat cycles and need to be replaced after a while anyways. IMO they are a wearable item just like the rest of the exhaust. I have seen manifolds after the wraps have been removed and they do have some surface rust on them but nothing I would believe to harm the structual integrity of them.....
I dont know where this rumor of wraps causing problems came from, maybe the V8 crowd because most of their headers were just mild steel and I could see that being an issue. almost all the tubulars you see these days are SS.
I always suggest contacting the manufacturer and doing what they suggest for heat retention just to avoid voiding your warranty
Old Jul 27, 2009 | 08:37 PM
Nice! I wouldn't mind spooling a bit faster. I can just get some for free if I want it. I will definitely ask Mines about it though. Thanks.
Momentum
Welding / Fabrication
Mar 8, 2010 05:01 PM
Sully90SiPrelude
Mar 15, 2007 02:37 PM
01ITR#700
Jan 11, 2003 04:38 AM
98lude
Sep 4, 2001 07:35 PM
