how to modify oem air box
Old Jul 26, 2009 | 06:05 PM
pascal514's Avatar
Default how to modify oem air box
well first off hello,im new around here and im serching all around and do not found anything on this.i ave 93 jdm prelude,what to no if someone no how to modify oem air box to be more efficient.ave read alot alot and correct me if im rong but it say that stock air box is better compare to cai ,short ram,ect.....if this is true it should be sticky ...photo or links would be nice ....merci
Old Jul 27, 2009 | 08:30 AM
pascal514's Avatar
Default Re: how to modify oem air box
anyone ???
Old Jul 27, 2009 | 09:06 AM
hondabigblock's Avatar
put a K&N air filter in your stock air box ? I have never heard of a stock air box being better than a CAI. Have you ever seen any high Hp cars with the stock air box? i haven't.
Old Jul 27, 2009 | 09:31 AM
pascal514's Avatar
__________________
my prelude is is not a high hp car !!!!!!!and the oem air box is desing to be there,i saw dyno sheet,cai ,sort ram ,,,but the oem air box always win,and theres a modification that could be done so more air flow
Old Jul 27, 2009 | 10:02 AM
92civlude's Avatar
Honda spent alot of R&D on air cleaner system that incorporates water/air separation. You would be surprised how many people suck water into thier engines when thier car is under warranty. So alot of design goes into water separation. What you could do to improve flow without comprimising design is remove the valve on the Intake Air System. Inside the fender, there are two intake tubes. One has a valve and the other is open. the valve is supposed to open at 4000 rpm. But by now, alot of those valves are rusted shut anyway. Just an idea.
Old Jul 27, 2009 | 10:05 AM
NirVTEC's Avatar
Look into the TypeS intake.
Old Jul 27, 2009 | 10:07 AM
92civlude's Avatar
Good idea. ICB motorsports has them.
Old Jul 27, 2009 | 11:40 AM
NirVTEC's Avatar
3" CAI dropped my IATs by 40* compared to 2.75" SRi.
Old Jul 27, 2009 | 01:32 PM
92civlude's Avatar
a high flow air filter too! K&N?
Old Jul 27, 2009 | 03:22 PM
__________________
I can't read jibberish. But whoever told you that a "modify stock air box" will flow better than a CAI is a idoit. Show me the dyno numbers where an OEM airbox "always won"
Old Jul 27, 2009 | 03:27 PM
ej1love's Avatar
i did this on my eg: 3in sri tube going into the stock air box, then shaved out the lines inside the box, and threw in a k+n filter. im may swiss cheese the bottom but this is better than the sri and cai i had before.
Old Jul 28, 2009 | 06:28 AM
pascal514's Avatar
https://honda-tech.com/zerothread?id=2049478
Old Jul 28, 2009 | 10:40 AM
c.dub's Avatar
Euro R intake manifold, AP2 throttle body, Type S intake chamber, K&N filter.
FTW.
JDMjoe86
Jun 1, 2007 05:41 PM
japmarket1
Mar 30, 2005 02:55 PM
p1driftfiend
18
Sep 3, 2004 06:04 PM
Rasta
Oct 5, 2003 05:43 PM
AMG
Nov 8, 2002 04:54 AM
