A/C question for b18 into a 1992 hatch
Old Aug 23, 2002 | 03:59 PM
vietpr1nce's Avatar
Default A/C question for b18 into a 1992 hatch
can someone tell me what a/c mount i can use so that the compressor is put on correctly. i had used the gsr mount for a few mounts but only 2 of 4 bolts fitted. can i use the DOHC delsol mount?? where can i get one for CHEAP???? im broke! thanks !!!!!
Old Aug 23, 2002 | 07:24 PM
B19CivicHB's Avatar
Default Re: A/C question for b18 into a 1992 hatch (vietpr1nce)
use the 94-95 vtec del sol bracket. about $140 from a dealer.
Old Aug 23, 2002 | 07:28 PM
LshatchTurbo's Avatar
New User
Default Re: A/C question for b18 into a 1992 hatch (B19CivicHB)
Goto Hparts.com, enter part # 38930-P54-000 or 434544. Either one is a 94-95 Del sol vtec bracket. Make sure it has P54 stamped on it whenever you get it. I buy them from there price runs $108 shipped UPS ground brand new.
Old Aug 23, 2002 | 08:12 PM
vietpr1nce's Avatar
Default Re: A/C question for b18 into a 1992 hatch (lshatchturbo)
thanks alot
Old Aug 23, 2002 | 08:33 PM
Dynamix's Avatar
New User
Also, what about power steering? How do you get power steering to work with a b18c1 inside a EG? Thanks
Old Aug 23, 2002 | 08:55 PM
beeboyee's Avatar
Default Re: A/C question for b18 into a 1992 hatch (Dynamix)
i think you can use the 99/00 si coupe mount also
Old Aug 23, 2002 | 09:27 PM
New User
Default Re: A/C question for b18 into a 1992 hatch (beeboyee)
99/00 si mount will only allow 3 out of the 4 bolts to screw in right. You could also use the integra mount and bolt in 2 out of the 4. Just save your self some time and money do it right the first time. No need to afro engineer in this case. Like i said make sure it has p54 stamp on the A/C bracket. 94-95 del sol vtec bracket
slowassBubble
Oct 3, 2010 04:24 PM
EJ8VTEC
May 18, 2005 08:56 AM
JSPECHB
Jan 9, 2004 07:41 AM
nicknasty
Nov 19, 2003 02:30 PM
chung
Jan 15, 2003 07:11 PM
