~*Ohio*~FS/FT 97 Civic Hatch 99-00 Front Built D16Y8 365WHP
The Car Has 130,000 on the Shell and the Motor/Clutch/Head and all new parts have around 5,000 miles on them.
Im open to any offer but please no Riced out cars and Trucks or bikes
Looking to trade for:
IS300
e36 M3
Stock 98-UP GSR
Stock 99-UP Civic Si
2000-up Jeep Grand cheeroke
E46 3 series BMW.
Mods:
Motor/Head:
-YCP 75.5mm bore Vitara pistons
-Eagle H-Beam Rods
-Hasting Rings
-Good year GatorBack Timing Belt
-New Water Pump
-New OEM Honda Oil Pump
-ACL Rod Bearings
-ACL Main Bearings
-ACL Thrust washers
-All New Gaskets and Seals through out the motor.
-New Metal 3 layer Head gasket
-The Head is stock but has been rebuilt and has new Vavle seals and a 3 angle Valve Job and has been resurfaced along with the block.
-B16 Throttle Body
Tranny/Clutch Etc..:
-The Car has a JDM D15B tranny with the optional LSD(Grinds 3rd and 4th if you shift fast and if you shift slow it doesnt do it at all)
-ACT 6 Puck sprung disk with Extreme Pressure Plate rated to 350tq
-OEM Flywheel thats been resurfaced
-New Axles with about 100 miles on them
-New Throw out bearing and Pilot bearing
-Always ran GM syncromesh tranny fluid
Turbo Kit/EMS/
-New Garret 57 Trim .48 exhaust housing .60 intake housing
-eBay Cast manifold
-eBay Wastegate
-2.5 in Intercooler piping
-Huge Front mount
-HKS SSQV Blow off Valve
-HKS Turbo timer
-Golden Eagle Vacuum Manifold
-Precision 880cc Injectors
-P72 Chipped with Hondata S300
-Walbro 255 fuel Pump
-Halmon ES Manual Boost Controller
-Braided Steel oil Feed and return Line with Russell an fittings
-Blox FPR and Liquid filled fuel pressure gauge
-3in Straight pipe exhaust
Wheels/Suspension:
-Koni Yellow Struts
-Ground Control Coilovers
-15in Ls Meshies 2 have new tires and 2 have falken azenis'
Exterior:
-99-00 front end conversion
-Black housing headlights
-5000k Xentec HIDS
-Invader2 Carbon Fiber Hood
Interior:
-98 Civic Ex Cluster
-99 Si/Ex Arm rest
-AC Autotechnic S7 boost Gauge
-AC Autotechnic S7 Oil pressure Gauge
-Amber climate control,cluster bulbs and LED Dome light
-CTR shift boot
-CTR CF cluster bezel
Bad:
-The drivers side quarter had some rust nothing major that previous owner tried to fixed it really doesnt look bad but it starting to come back out.I had plans of fixing it and respraying the whole car if I kept it.
-It could use a new OBD2 jumper harness because one of the pins is loose and sometimes it will cause the ecu to go to limp mode.
WILL NOT COME WITH THE DEL SOL SEATS OR GRAM LIGHTS.
IS300
e36 M3
Stock 98-UP GSR
E46 3 series BMW.
Mods:
Motor/Head:
-Eagle H-Beam Rods
-Hasting Rings
-New Water Pump
-ACL Rod Bearings
-ACL Main Bearings
-ACL Thrust washers
-B16 Throttle Body
Turbo Kit/EMS/
-eBay Cast manifold
-eBay Wastegate
-Huge Front mount
-HKS Turbo timer
Wheels/Suspension:
-Koni Yellow Struts
Exterior:
-5000k Xentec HIDS
Interior:
-99 Si/Ex Arm rest
-CTR shift boot
Bad:
saw you were looking for an E36 M3
Check this out http://www.autotrader.com/fyc/vdp.js...standard=false
Its not mine but I think it looks like a good deal.
Bump Car Finally has a 3" exhaust straight pipe back to a OBX greddy knock off muffler also here are some new pics of it some random ones are thrown in the engine bay is kinda of dirty and I need to get the some pics of the interior.
