another new PB after attending the turboschool.com
Old Jul 26, 2009 | 01:23 PM
d16z6Tcrx's Avatar
Default another new PB after attending the turboschool.com
not as fast as the other guys but it works for me. daily driven
92 eg
stock gsr
t3/67
10psi..........gauge reads 10 logs read 13.7
93 oct
stock open diff
22 inch slicks........... all i had
r/t: .554
60: 1.708
330: 5.123
1/8: 7.814
mph: 90.48
1000: 10.11
1/4: 12.035
mph: 116.74
then backed it up with
r/t: .008
60: 1.836
330: 5.242
1/8: 7.917
mph/: 92.58
1000: 10.179
1/4: 12.096
mph: 113.30
in my logs im seeing a mph going the the traps at 124-127. i know the tires are way too small but it gives me hope. the goal is to go 11.50s how it sits.
after the class I played with the tune a little bit. I learned about munipulating the tune to spool the turbo faster. then i moved some weight around and relaxed the chassis. the car pushed nicely now all by myself.
again thanks to Dan and Dave from the turboschool.com. miller for the small talk. rob from low budget for the driving tips. kevin from MB Racing for the manifold and anybody else i forgot.
UPDATE:
R/T :.578
60' :1.736
330 : 4.946
1/8 : 7.580
MPH :95.34
1000: 9.816
1/4: 11.732
MPH: 119.10
THANKS AGAIN TO NRGTECH AND THE TURBOSCHOOL.COM
Old Jul 26, 2009 | 01:28 PM
96 GSR-T's Avatar
Default Re: another new PB after attending the turboschool.com
congrads, interesting differences between the 2 passes (typo possibly?), you were .06 faster to the 1000' mark on the first pass vs. the 2nd but finished .26 faster on the 2nd..... thats a hell of alot of ground to make up in 320ft
Old Jul 26, 2009 | 01:48 PM
d16z6Tcrx's Avatar
very right. edited
Old Jul 26, 2009 | 04:51 PM
turbodano's Avatar
Congrats Rodney thats awesome.
Keep up the good work man. Are you coming back up for round 2 at NRG on the 8th?
Old Jul 26, 2009 | 05:22 PM
boosted91crx's Avatar
why not video the turbo school session and put on you tube for those who cant go to them.
Old Jul 26, 2009 | 05:31 PM
turbodano's Avatar
We are planning on doing a live interactive class from the Indy location.
You may want to go ahead and down load ventrillo.
Old Jul 26, 2009 | 06:40 PM
d16z6Tcrx's Avatar
dan i just might. the schedule said 7th,8th,9th though. ill give miller a call this week.
Old Jul 26, 2009 | 06:45 PM
i already have ventrilo on my pc . also teamspeak.
Old Jul 26, 2009 | 07:04 PM
Boner_Ben's Avatar
I'm sure the info from Dan and Dave is worth something to them, everybody always wants something for free these days!
Old Jul 26, 2009 | 07:10 PM
its just a suggestion for those who cant attend. some people have no time to get away from work and family.
Old Jul 27, 2009 | 05:09 AM
d16z6Tcrx's Avatar
thats understandable but the being there is way more benificial.
Old Jul 27, 2009 | 06:25 AM
Rogue108's Avatar
I was thinking the same thing. Dan and Dave's experience is worth something. If their knowledge was that easily gained we would all know. I understand that all a lot of folks can't get away for things like this. I would thinking an online pay per view or ventrilo as Dan recommended is fair. The only problem with online pay per view is the upfront setup costs.
To OP - Nice change in the times.
Old Jul 27, 2009 | 07:27 AM
d16z6Tcrx's Avatar
thanks
Old Jul 27, 2009 | 12:21 PM
d16z6Tcrx's Avatar
anybody have that happen before? where your logs say one mph but your time slip says another. just want to make sure my system is correct. maybe its all wheelspin????
Old Jul 27, 2009 | 12:52 PM
gringotegra's Avatar
i know that your trap speed is an estimated speed.... dont quote me but i think its 60ft at the end of the 1320 and your trap speed is an average speed across that 60ft.... so when you enter that first part of the end you are travelling at a lower speed than when you cross the finish line...just something to think about there...
i think your 22in slicks are killing you tho ... you are shifting 5th i take it right?
Whats wierd is how you were up 2mph in the 2nd @ the 1/8 but ended up being down 3mph at the finish..?
Old Jul 27, 2009 | 02:16 PM
logs are always off from trap unless you have teh proper size slicks, however then its still laggy, what i mean is do a pull in 3rd and have a buddy watch your speedo and the laptop at the same time, the laptop will show the mph a second or so behind the speedo, so when you cross the line and lift the pedal the logs are just a little behind what you really hit. now i have only personally seen this in s300 and neptune not sure about other set ups.
Old Jul 27, 2009 | 02:55 PM
96 GSR-T's Avatar
my logs in Neptune were almost 10mph slow vs what the timeslip said going through the traps with 24.5's, with my 185/65/14's they were alot closer.
Old Jul 27, 2009 | 04:47 PM
d16z6Tcrx's Avatar
i thought about that after i talked to some people. also i never set my gear ratio in s300 either. im still getting used to it.
yea they are. it spun the whole track. i couldnt even read the tach, i just shifted when i heard the limiter. yea i shifted to 5th the first run on the second i shortrd 3rd and went thru the traps on the limiter in forth.
im going to get 24.5s and a retune before i go back.
thanks for all the replies
Old Jul 27, 2009 | 04:57 PM
ciscoscivic's Avatar
nice runs man, if you need the 24.5's let me know i can have the set paired up for you and drop shipped to your door cheap for a fellow turboschool guy
Old Jul 27, 2009 | 06:13 PM
d16z6Tcrx's Avatar
thanks man will do. you guys headed back in august?
Old Jul 27, 2009 | 06:24 PM
maybe but we had it tough losing 2 days, it was all worth it, but right now to loose 3 days just might not be in the cards, but indy sure seems nice.
Old Jul 28, 2009 | 03:38 AM
d16z6Tcrx's Avatar
o ok
Old Jul 28, 2009 | 04:07 AM
REEMB18C1's Avatar
24.5 roodddddd
Old Jul 28, 2009 | 05:52 AM
d16z6Tcrx's Avatar
i know i need some wheels first reem wassup......
Old Sep 23, 2009 | 06:51 AM
d16z6Tcrx's Avatar
update
eg64u
Feb 13, 2015 05:36 AM
B(eighteen)C
Feb 24, 2013 08:15 PM
hellajdm333
Appearance Build Threads
Feb 17, 2010 12:45 AM
BoostFrenzy.com
Apr 21, 2006 03:23 PM
