need help 91 integra turbo or na?
Hey, i would like to turbo my 91 integra that is Stock (B18A1) except full Exhaust and cold air intake.
what should i do to my engine to make it last and handle the turbo?
or is is even worth turboing? should i just go NA? thanks.
PS i dont wana do a Swap and heres a list of parts ive ordered, i can still cancel on the parts if there unnessesary thanks.
b16 head with dizzy
P28 ecu chipped
Stage 3 Bully Clutch
ACT 8lb flywheel
Skunk 2 intake manifold
68 mm throttle body
Carbon fiber hood
Hasport performance drive shafts
b16 head with dizzy
P28 ecu chipped
ACT 8lb flywheel
68 mm throttle body
Carbon fiber hood
your on a pretty good track now...depending on how much boost your are going to run you will be fine on stock internals. the only thing really you should look into with stock internals is new rings and such...but if you dont want to tear the motor apart at least get a new head gasket and ARP head studs. the reliabilty is really all in the tune...so make sure you have it tuned by a rebutable tuner.
