"TURNING" the distributor???
Old Jul 26, 2009 | 12:43 PM
hannslebo's Avatar
Default "TURNING" the distributor???
Ive heard that you can adjust your idle a small amount by turning the dizzy...i looked at the dizzy and it does have a little play in it where you could move it a small amount?? anyone ever heard/done this??
Old Jul 26, 2009 | 12:50 PM
rvd6669's Avatar
Default Re: "TURNING" the distributor???
on a v8
Old Jul 26, 2009 | 12:53 PM
hannslebo's Avatar
ok...well that kinda makes sense. the guy who told me this has been around V8's all his life.
so this CANNOT be dont on a honda/acura?
Old Jul 26, 2009 | 12:54 PM
JonMaltese/LScivic's Avatar
ya its called adjusting your ignition timing.. i wouldnt move it at all unless u have a timing light .
Old Jul 26, 2009 | 12:56 PM
starion88esir's Avatar
Originally Posted by rvd6669
on a v8
hahahaha! Thanks for the laugh!
Old Jul 26, 2009 | 01:01 PM
moving the dizzy forward and backwards will retard or advance the ignition timing. if u advance it too much your engine will not last long..
Old Jul 26, 2009 | 02:35 PM
Vindicator9000's Avatar
318 Curves, 11 miles
You adjust the idle using the idle screw on the throttle body, but 99% of the time, if you're idle is messed up, there's something else that you should fix first.
Turning the distributor retards or advances the timing, as someone else said. You should use a timing light if you want to adjust it properly.
Kyogie12
Dec 18, 2011 05:48 AM
2kdrift
Jul 30, 2010 11:55 PM
es_squared
Nov 16, 2008 01:49 PM
shadohconspiracy
Apr 20, 2008 04:21 PM
bassysingh
Oct 17, 2005 10:02 AM
