What Do I need to swap in a H22A4?
Not to over look the obvious, I know I need the engine and trans, wireing harness, ecu. What else do I need ? Also how much should the ECU cost? I found a good price on motor and trans Im also looking for a LSD and a reputable shop to do the swap im not quite ready to tackle a project of the stature yet, nor do I have a place to do it.
NO Dis respect. But the you don't need the motor mounts. I am doing a swap. 2001 H22a4 And so far we had to use the old harness. I still have to tackle in finding a ECU and some wire plugs...the one in the H23a are shorter.
i have done this swap. you do not need a new wiring harness, you do not need a new distributor and you do not need new motor mounts. the ones from your old engine will all work. also for the PS bracket you will need to use a ricriprocating (sp) saw to modify it to fint the h22a4 block. and as for an ecu, the p13's are really expensive so i just got a p28 for dirt cheap and had a hondata stage 2 system installed on it for about $200 more, i mean **** you'll prolly get a VAFC later anyway why not?
alien
Jun 14, 2006 10:31 PM
