Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
ECU Wiring
Old Jul 26, 2009 | 11:52 AM
julezeve's Avatar
Default ECU Wiring
I did an auto swap on my 02 civic ex, yesterday I changed the engine harness to manual as well as the ECU and ignition, now my car won't start.
I am still using the auto dash harness does anyone know how to wire up the Clutch pedal?
all the lights and everything turn on my the car just won't start and its not because of the key because I have the key for the new ECU.
if anyone knows how to wire up the Clutch pedal please help, how if you think you know any other reason the car won't start let me know. thank you.
Old Jul 26, 2009 | 12:10 PM
julezeve's Avatar
Default Re: ECU Wiring
did a little research and found i have to ground one wire on the clutch and wire up another but no one seems to mention where to wire up the other wire. please help
Old Jul 26, 2009 | 12:11 PM
HONDAPARTSMANMIKE's Avatar
is your immobilizer light(green key light) flashing when you are cranking over the car. ecu has to be and immobilizer system need to be reprogramed by your local honda dealer
Old Jul 26, 2009 | 12:15 PM
julezeve's Avatar
the light don't flash I got the key for the ECU.
Old Jul 26, 2009 | 12:32 PM
all you should have to do is ground the LT/GR wire at the clutch switch or ground the BLU/WHT wire at the trans range switch. here a diagram that might help you
Old Jul 26, 2009 | 12:39 PM
julezeve's Avatar
and what do I to the other wire? do I did another wire? because the clutch sensor has two pins. thank you so much for your help
Old Jul 26, 2009 | 12:43 PM
you have a clutch sensor connector correct??if so just connect both wires together. you can use a paper clip or just splice both wires together.
Old Jul 26, 2009 | 12:56 PM
julezeve's Avatar
no its just the empty connector because I am using the Auto Dash Harness.
Old Jul 26, 2009 | 01:22 PM
ok what you gonna have to do is refer to the attached diagram ref#7 is connector d (LT GRN connector) pin 7 is LT/GRN wire just ground that wire. also refertothe previous diagram
File Type: pdf
Old Jul 26, 2009 | 01:30 PM
julezeve's Avatar
I am a little confuse. so I ground the LT/Green wire and also ground the BLU/WHT?
Old Jul 26, 2009 | 01:35 PM
julezeve's Avatar
can you private message me your phone number please im so stuck
Old Jul 26, 2009 | 02:03 PM
heres the connector pin out for D7
File Type: pdf
Hanmin
Audio / Security / Video
Aug 8, 2010 07:41 AM
JDM-EJ1
Jun 23, 2005 07:05 AM
jtracing919
Jan 11, 2005 06:45 AM
Sketch_hs
Aug 19, 2004 08:44 AM
Mark27
Apr 13, 2002 08:30 PM
