b18b eg bogging when under battery load
drove car to work fine
got off work and it was 1am and drove off fine with hid's(8k) and some other stuff on
now once driving i turn on stereo and heat, car almost immedietly bogs at about 2800-3500 rpm
when i hit wot it somewhat goes away
now here the good part, once i turn off the electronics the car goes fine immedietly, this is what i did
cars bogging 3k rpm, turn off heat and stereo and dim lights, no boggig
or turn of hid's and no bogging
im stuck really and need some suggestions on what to test, im thinking battery/altrnator maybe tps sensor
no cel
no cel
im thinking the alternator is it too, ill be buying a new volt meter tmmarow, i cant find mine
but would shortage of power cause tbs sensor to go off
i get code 7 sometimes
12.2 volts on battery(this is a gel braille) battery, while cars off of course
and when cars on the battery is pushing out 13.7-13.8 volts, sounds good to me
so whats wrong
is my alt too weak or needs more output, guy told me to hook up two batteries to it or a larger one
notice this only happens when my electronics are on(hid's,stereo,heat and such) when i turn them off everyhting goes good
and my lights dim at idle when i give it gas it slowly goes bright and normal
stills bogging under electrical load,
i just checkded and the battery is pushing 12.8 volts
and under electrical load when car is on the battery shows 12.4 volts, thats with hid and stuff on
check all your grounds.. it could also be the ELD going bad.. is your distributor timed correctly? just another thing to think about..
grounds checked and some retightened and cleaned
could it be that im using a small braille cf battery pushing 200 amp cold
its a samll battery
its a samll battery
could be since 12.2v for an automitve battery is actually 50 percent charged.
i really have nothing else to comment on...im kind of lost but bad batteries can do weird things.
how old is the battery?
what are you running for a radio?..subs? amplifier? 12.4 with electronics on isnt really charging...
ill wait with a reply before i continue on
i might beielbe it could be the feul pump, just put a new battery in and same old same, even hooked up two batteries to it
ok i took of the tbp sensor and the car runs like a charm wit everyhting on, but once i connect it same thing starts to happen again
could i have a bad tbp sensor, ill be replacing it soon with a new tb and gaskets
I believe he does Ron.
Just make sure WOT and idle are adjusted to correct voltages (WOT being adjusted first) and it should run like clockwork.
i probaly dont have to adjust because ill be putting in a used tb with one on it
yeah meant tps srry
thanks again guys
how do i adjust it
I agree with ^^^ The ELD should see that electronic load is there and jump up the voltage from the alt. Just remember the stock map on you car has an adjustment for the battery voltage offset. That means that the lower the volts the higher the ms the injectors have to fire. Im guessing that the ALT is not amping up to the higher demand of power therefore not delivering the volts needed. My civic does 14.2 v when headlights and ac is on. Just some info
Adjustment for WOT is done by loosening the screws holding it onto the TB and moving the TPS left and right. I honestly forget which way moves the voltage up or down, but just play with it until you reach spec (4.5v).
Adjustment for idle is done by turning the idle screw on the TB. Its different places on different TB's but you should be able to find it fairly easily. Spec voltage is 0.45v to 0.50v.
adjusted still same thing happeing, runs fine without headlights and heat on, and runs fine if its not plugged in no matter whats on
Here are my results:
Car off -- 12.89V
Car idling no electrical load -- 14.34V
Car idling high electrical load (high beams, A/C, blower max) -- 14.01V
OP -- Have your alternator tested. I think replacing it may solve your problem.
