new short shifter
new to the forum, cheers guys.
im about to get a short shifter for my 98 hx,
just wondering what the difference is between a single bend and a dual bend.
which one will give me the shortest pull?
also is b&m a legit company?
When you install the shifter there is a fine line on how much you tighten the rod... Too loose and it will be sloppy and too tight and it will be hard to shift... It took me a couple times playing with it before I got it just right... Also get the energy suspension bushings, nothing makes a bigger difference than those...
hey orange park, does the prelude shifter mount different than the del sol? cause I wanted to order those and I think my shifter base got swapped with the H23
PS I am from eagles bluff, and grew up out on kingsley
I honestly couldn't tell you man, I am not overly familiar with H series engines or Preludes for that matter... I wouldn't want to give you the wrong info...
I just moved here 2 months ago from MD and absolutely love it... Moving to FL has changed my life...
im using a gsr stock shifter in my 97 civic. i love it, throw is just right and it feels great. dont spend like 100 bucks from b&m for the same thing....
if you get a cheapo short shifter that makes the throw too short, sometimes it makes it harder to shift and easier to miss gears, plus you run into exhaust fitment issues.
. GSR shifters are great. a buddy of mine has one in his 97 coupe.
