How to remove bolt?
working on brother-in-laws car, after he bent both control arms on his driver rear side...
i cant figure how to get the cam bolt of (bolt 28)
anyone help
1996 - Accord Sedan
http://www.hondaautomotiveparts.com/...REAR+LOWER+ARM
anyone help
1996 - Accord Sedan
i dunno what else you have going on there, but hold bolt 57 down with a wrench or cresent wrench, then unscrew the 28 bolt with rachet and socket going in reverse.
If thats the bolt I think you are referring to I don't see what problem is. Is the bolt frozen in the bushing? Matybe use an air hammer on opposite side to punch it out. Air, heat and yelling usually work.
i had a similar problem, its rusted in. try hammering out if you havent already. It was mentioned to use heat, or have someone move the arm up and down (prybar) while you try to remove the bolt.
