Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
03 Odyssey code 0505 and 1129
Old Jul 25, 2009 | 04:47 AM
hondateched's Avatar
Default 03 Odyssey code 0505 and 1129
I have a 2003 Odyssey with 78K, and it has has an intermittant CEL. I retieved codes 0505 and 1129, issues with the IAC. I am planning to clean the throttle body and and IAC.
I have read several post on replacing the IAC and I found a Honda SB that recommends replacing the IAC with a newer (improved) unit P/N 16022-P8A-A02.
I priced this with my supplier at $150. Can anyone suggest other Honda parts suppliers?
Thanks, Ed.
Old Jul 25, 2009 | 06:53 AM
Default Re: 03 Odyssey code 0505 and 1129
bump
Old Jul 25, 2009 | 07:49 PM
Well, I removed and cleaned the throttle body, IAC and reinstalled. I found the air filter box only secured by two of the four bolts, and the clamp to the intake at the throttle body not tight. The throttle body did have a build up of residue around the down stream side of the baffle, and the IAC did not have more than minor deposits.
Once I reinstalled and test drove, no irregular idle or hesitation. I told the owner to drive the car and see if it faults again, then I will change the IAC per a SB I found on CEL 1129 an 0505.
Jeeptech
May 19, 2017 08:12 PM
phelpsj2
Nov 3, 2011 02:35 PM
aznlaoboi315
Jan 25, 2008 03:11 PM
SkyliteCustomz
Honda Civic (2001 - 2005)
Nov 12, 2007 01:59 PM
bluevic99
Jun 5, 2006 02:55 AM
