Suspension & Brakes Theory, alignment, spring rates....
What shocks with Eibach Sportlines (05 RSX-S)
Old Jul 24, 2009 | 06:34 PM
c'mon's Avatar
Default What shocks with Eibach Sportlines (05 RSX-S)
I've done a search, but there seem to be a lot of conflicting "opinions" on this.
I had always been under the impression that Koni Yellows do fine with the Sportlines (or any springs with a similar drop), but I'm reading now that the Knois don't handle a drop lower than 1.5 very well.
So the question is, what are the other options?
Old Jul 24, 2009 | 08:24 PM
STOCK_SOHC_DX's Avatar
Default Re: What shocks with Eibach Sportlines (05 RSX-S)
The yellow's pretty much handle almost anything you throw at it. The spring rate makes the difference but I have my yellows with coilovers and pretty much dumped and they are great.
Old Jul 24, 2009 | 11:31 PM
racebum's Avatar
yellows will easily handle sportlines. you might even be able to squeeze by on the str.t if you don't plan on ever increasing the rate past sportlines. the yellows are the better shock & if you can afford it, do so
Pure Sol
Suspension & Brakes
Apr 28, 2009 01:53 PM
Chaveli
27
Mar 30, 2008 08:01 PM
tekstyle
Sep 14, 2002 02:19 PM
doe
Jul 29, 2002 09:44 PM
2fast
Feb 12, 2002 09:32 PM
