97 DX Overheating problem
Old Jul 24, 2009 | 05:48 PM
oaklandwilly's Avatar
Default 97 DX Overheating problem
For the last couple of weeks, my car has been overheating when I have turned on the ac. I checked my reserve and it was bone dry. I filled it up, and today, it was bone dry again. I was leaving my car when I heard my reserve boiling. I had a new radiator put in last year because it was cracked. I think it might be a head gasket problem, but I'm not sure. Any more info? It would help a whole lot. it's very stressfull
Old Jul 24, 2009 | 05:53 PM
black0hatch's Avatar
Default Re: 97 DX Overheating problem
ya sounds like a head gasket to me. same thing happened on a coupe i used to have. the resevior will boil over then when it cools down its bone dry. thats a head gasket.
Former User's Avatar
Fill not only the reservoir with coolant but also the radiator. Also consider replacing the thermostat and radiator cap and then bleeding the cooling system.
With respect to a possible blown head gasket, you may want to compression test the cylinders and do a cylinder leak down test.
Old Jul 24, 2009 | 05:56 PM
Sorry about not mentioning that I did fill up the radiator with coolant. Can anyone send a link on how to remove/replace the head gasket?
Old Jul 24, 2009 | 05:59 PM
its super easy. get a repair manual or search for it here. also search about the blown headgasket youll see lots of people have the exact same symptoms as you i did too. the most important part of doing a head gasket is the torque sequence and specs. also if you overheated it really bad make sure the head and block arent warped. thats usually not a problem though.
Old Jul 24, 2009 | 09:47 PM
the culprit was the radiator cap. It was done. Thanks everyone.
Old Jul 26, 2009 | 01:50 PM
Bad news it still goes up in temperature when i come to a stop. Any suggestions? The water is fine. No boiling in the reserve.
Old Jul 26, 2009 | 02:09 PM
Does the fan run?
Old Jul 26, 2009 | 02:19 PM
Yes I am going to change my thermostat and bleed it now
Old Jul 28, 2009 | 10:08 AM
Which fan do I check? Would a bad fan cause those symptoms? It doesn't overheat when I have the ac off.
Old Jul 28, 2009 | 10:20 AM
Just wanted to note that the temperature goes up when I stop and when the ac is on. Maybe the fan?
Old Jul 28, 2009 | 12:09 PM
You have two fans, one behind the radiator and one behind the A/C condenser. The radiator fan should run when the engine is hot, whereas the condenser fan should run whenever the A/C is on.
Old Jul 29, 2009 | 05:26 PM
Ok here is some more news. I am leaking a whole lot of water when the ac is on. I open the hood and saw it's coming from a little tube. Also a loud screeching will occur. Possibly my water pump causing all this mess?
Old Jul 29, 2009 | 05:45 PM
Null zahlen's Avatar
What little tube?
Old Jul 29, 2009 | 06:06 PM
The weep hole possibly.
Old Jul 29, 2009 | 06:19 PM
The leaking water may just be water condensation produced by the A/C when it chills the air. There's a drain tube below the evaporator on the front passenger side of the car. The loud screeching may be a loose A/C belt.
Old Jul 29, 2009 | 06:53 PM
There is a fluid dripping from my exhaust.
panchlow
Dec 18, 2010 11:43 AM
spruman03
Honda Civic (2001 - 2005)
Jul 6, 2008 11:40 AM
AcidFr33ze
Jan 7, 2006 07:18 PM
B17AGSR
Jun 8, 2004 07:23 AM
5thgencivic
Mar 25, 2003 12:46 PM
