Turbo GSR Breaking Up In Boost...hondata s300
original thread: https://honda-tech.com/forums/forced-induction-16/breaking-up-boost-2613385/
Any of you all have any ideas of what to try? I don't know much else to try besides a different hondata ecu. I have the hondata s300 program if anyone wants to take a look.
2.0L turbo GSR. Hondata S300. The motor will not go over 4900 rpm/3# of boost. At that point it just breaks up and feels like it is hitting a rev limiter. This problem just started recently. I have already tried swapping the igniter, coil, and new plugs. I've tried the plugs gapped all the way down to 20 thou with no luck. I have tried both resistor and non resistor plugs in it. I don't feel it is tune related as the car has been running fine. The AFR is 12.3:1 at 3# when it is breaking up.
Any ideas?
Any ideas?
My guess is the issue is ignition system related still.
Who originally tuned the car ?
Why don't you take it back to them to have them troubleshoot it ?
Just a thought, I actually had someones map sensor vacuum become disconected and cause a similar problem. I didnt read the previous thread to see if what you had a stock type map sensor or a motec/gm 3 bar.
Generally when that occurs, the air fuel ratios will be completely thrown off in boost.
The MAP is fine. We thought about it and decided to go back to the OEM one just to see. The tuner adjusted for the stock MAP and the car still breaks up at 2.x# of boost. We pulled a coupler off the charge pipes and the motor would run fine to 7k rpm. The problem only under a load where boost is created. We tried a brand new dist. and new wires. Same problem. We tried new plugs, resistor plugs and non resistor plugs, and adjusted the plug gap. No difference. I am starting to think it is something in the S300 box that is wrong unless you all have other suggestions of what to check.
AFR looks good.
AFR looks good.
Now after all ur troubleshooting of the ignition, plugs, etc. You said the a/f is ok, the other thing you could check is resrictive air flow either to the turbo(i.e. too small of filter) or some kind of blockage within the intercooler and piping.. Just something to look at. I had a customer put a filter on his turbo after tuning and made it break up underload, took it off and car ran fine..
Try another wideband to make sure your wideband is accurate.
Try another complete distributor assembly from another vehicle which you know works perfect, none of the discount auto parts crap...
