Resistor box required? 1000cc low resistance injectors
Old Jul 24, 2009 | 12:57 PM
jetspeedz's Avatar
Default Resistor box required? 1000cc low resistance injectors
I did a search and it looks like if i get low resistance RC injectors i won't need a resistor box correct. This will be going into a p72 obd1.
http://cgi.ebay.com/ebaymotors/RC-Fu...Q5fAccessories
Old Jul 24, 2009 | 01:03 PM
TheShodan's Avatar
Moderator
Default Re: Resistor box required? 1000cc low resistance injectors
yes. you will if they are about 2.5-3 ohms
Old Jul 24, 2009 | 01:04 PM
jetspeedz's Avatar
Ok thanks i guess ill be needing that box then. And can i hook up the box while the stock injectors are in the car till im ready for the new injectors?
thanks
Old Jul 24, 2009 | 01:48 PM
jetspeedz's Avatar
TheShodan was kind enough to answer my question in case anyone else is interested you can not use the resistor box with the oem injectors. just a heads up
Old Jul 27, 2009 | 05:48 PM
kreatekustomz's Avatar
yeah what would be the point in using a resistor box with OEM injectors?
Not to still your thread but what is the stock resistance of OEM injetors?
Old Jul 27, 2009 | 05:53 PM
iTz On!!!'s Avatar
i have a set of injector dynamics 1kcc that doesnt require resistor box if your interested. its brand new
Old Jul 27, 2009 | 07:14 PM
redflaredcrx90's Avatar
many civics integras accorrds and preluds used resistor boxes on stock injectors
ej1serge
Mar 14, 2012 11:33 PM
boosted96teg
Mar 15, 2008 06:35 AM
deucedeuceEK
Oct 30, 2007 04:35 PM
B18 CYA
Jun 24, 2004 06:44 PM
