Suspension & Brakes Theory, alignment, spring rates....
??? on replacing my Civic brake master cylinder.
Old Jul 24, 2009 | 10:18 AM
gabebauman's Avatar
Icon6 ??? on replacing my Civic brake master cylinder.
I'm gonna be replacing the Brake Master Cylinder in my '93 Civic Cx Hatch this weekend and just read thru this very nice DIY thread for the ITR mc/booster swap: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-jdm-1%22-itr-mc-bb-into-civic-install-818263/
My question is, when removing the old mc from my brake booster...do I need to crawl under the dash and remove the cotter pin from the clevis pin behind the brake pedal? or can I remove the mc from the booster with just the two nuts that attach it to the brake booster from the engine bay?
Thank You & God Bless
Old Jul 24, 2009 | 10:33 AM
hybrid90's Avatar
Default Re: ??? on replacing my Civic brake master cylinder.
Originally Posted by gabebauman
I'm gonna be replacing the Brake Master Cylinder in my '93 Civic Cx Hatch this weekend and just read thru this very nice DIY thread for the ITR mc/booster swap: https://honda-tech.com/forums/showthread.php?t=818263
If it's just the MC, then it's just 2 bolts and two brake lines. Don't forget to bench bleed your MC before installing...
Old Jul 24, 2009 | 10:47 AM
gabebauman's Avatar
Thanks man. Yes...I have my bench bleed hose setup ready to go as well.
Will I need to bleed the brakes after the new mc has been installed and hard lines hooked back up? I just bled the brakes last week.
Old Jul 24, 2009 | 11:06 AM
K20egcw's Avatar
Yeah your gonna need to re-bleed your whole system again
Old Jul 24, 2009 | 11:07 AM
gabebauman's Avatar
Thanks...I figured that...just wanted to be sure.
Old Jul 24, 2009 | 12:23 PM
phunhaus's Avatar
Yes you're going to have to remove and replace that cotter pin.
AWD: Jeff
Suspension & Brakes
Jul 3, 2010 06:47 AM
mixmastabob
Dec 7, 2006 12:09 PM
blulude92
May 26, 2006 10:03 PM
magbarn
May 22, 2003 03:28 PM
Eggman
Oct 6, 2002 09:32 AM
