HondaBond on Headers???
Old Jul 24, 2009 | 08:12 AM
bopbop93030's Avatar
Default HondaBond on Headers???
Can you use this on the headers and downpipe? or do you recommend something else.
Thanks!
Old Jul 24, 2009 | 08:16 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: HondaBond on Headers???
I doubt Hondabond is going to help seal an exhaust leak, the exhaust is probably too hot.
are you trying to seal a small crack/hole or where they join? If a small crack or hole, try JB Weld or get it actually welded. If it's at where they join just get a new gasket.
Old Jul 24, 2009 | 08:25 AM
hondamark35's Avatar
Permatex makes a muffler and tailpipe sealer... there are also other similar products from other brands, i just can't think of the names.
Old Jul 24, 2009 | 08:34 AM
02AccordSE's Avatar
No it won't work. Most cold weld products has a temp hold of 600 degrees max. I tried to JB weld my headers and the weld just turned into a powder. Take it to an exhaust shop. To weld up headers should be about $100.00
Old Jul 24, 2009 | 08:42 AM
02AccordSE's Avatar
Hondabond is used for gaskets not fill cracks.
If you aftermarket headers like DC Sports, they reach temps around 1100 degrees. That silicone Hondabond will also burn off.
Old Jul 24, 2009 | 09:59 AM
I will be replacing the header gasket soon, I already ordered the parts from Majestic Honda.
I just thought by adding something there will insure a leak free headers.
Ok. is HondaBond ok to use on Oil Pan then? I got the OEM gasket already and I will doing that and the headers at the same time.
Old Jul 24, 2009 | 11:19 AM
02AccordSE's Avatar
Hondabond should work on any gaskett. As far as the headers go, if installed correctly there will be no leaks.
Old Jul 24, 2009 | 12:29 PM
accord99power's Avatar
agreed x2, also i beleive RTV Sealant RED is for exhaust, i cant remember for sure, check autoparts store or google.
weiRtech
Welding / Fabrication
Aug 21, 2009 06:22 PM
2.0L Beater
Sep 25, 2007 07:20 AM
5G_Vtec
Jul 15, 2007 06:39 AM
bgoetz
Nov 20, 2003 08:11 AM
