chipped p28 to a act as P13 possible?
hello guys
well i forgot my pgmfi.org password so i decided to ask this question here.
is it possible to run a p13 rom on a chipped p28 ecu and run it on H22A swapped 94 accord??
thanks
thanks
Yes a P13 map will work on a chipped P28 ECU. Just remember that it would be a base map. Some slight/fine tuning would still be a good idea. In order to get it to perform properly.
*Edit - IIRC You won't have the use of ECU controlled IAB for the H22 manifold. Unless you physically add the components to the P28 ECU.
thanks fo the info,
where did you find the bin for the H22?
did you had to repin some of the ecu wires?
Seriously - Accord FAQ
I get the impression you don't know anything about chipping ECU's and I'd suggest buying a pre-chipped and pre-flashed ECU with an H22A basemap. From a company like Phearable, since I have an inkling that's your next question.
I'd recommend using a chipped P72 ecu, since they have the IABs and you can obtain that from xenocron, phearable, or Honda-Tech user Monotech. He does great chipping work and can add IABS to a P28.
wtf?? clearly you didnt read anything.
i asked which wires do i need to repin, not your opinion about my knowledge.
