HELP! NEW BUILD LOW COMPRSSION
Old Jul 23, 2009 | 05:14 PM
SANTANA5STAR's Avatar
Default HELP! NEW BUILD LOW COMPRSSION
This motor is a ls\vtec. Everything is new and was pu together by a shop around my old neighborhood. well i ran a compression check after the motor would not start .... all wiring has been checked. all the cyclinders read below 80.
suck as 60 80 90 70. what could the problem be.... i was thinking head gasket but i am unsure
Old Jul 23, 2009 | 05:36 PM
Ruben19's Avatar
Default Re: HELP! NEW BUILD LOW COMPRSSION
ii don't think is the head gasket unless they used the wrong one. did they install new valves?
Old Jul 23, 2009 | 05:40 PM
no new valves.... it a b16 head/// the valves are not bent... when i crank the the car i get a lil backfire from the intake and a sputter here and there but no reall sign of starting
Old Jul 23, 2009 | 05:44 PM
should my compression be reading that low since the car hasnt set the rings yet?
g230sport's Avatar
sounds like possibly your timing is off, throw a timing light on it and just check that. you might be a tooth or so off on your timing belt.
Old Jul 23, 2009 | 05:45 PM
Null zahlen's Avatar
If you can and have the proper tools available, do a leak down test. It's much better then a compression test.
Old Jul 23, 2009 | 05:47 PM
is that were i add a lil oil while doing a compression test or explain ?
Old Jul 23, 2009 | 05:50 PM
Ruben19's Avatar
that's what im thinking too.
Old Jul 23, 2009 | 05:53 PM
that would cause me not to start???? also i am still worried about the compression lvl......... also with the timing light doesnt that require the orginal pulley?
nope, the air leak down test is using air and the "air leak down tester" to pressurize the cylinder in question. Then you would need to hear where in the engine the air is leaking.
Old Jul 23, 2009 | 05:56 PM
okay can i get a leak down tester
also with the car never being ran.. doesnt that mean my ring arnt sealed right now anyway.?
Old Jul 23, 2009 | 05:57 PM
philafelman's Avatar
ur supposed to do a compression test with the car fully warmed up and WOT while cranking...if ur car hasnt started yet, it could affect the numbers. make sure you have fuel and spark and the correct firing order.
Old Jul 23, 2009 | 06:02 PM
Yes, that is one of the reasons a car wouldn't start, but their are several other reason like no gas, no spark, fuel pump gone bad, etc, etc.
what is the correct firing order just to be sure
Old Jul 23, 2009 | 06:35 PM
bump
Old Jul 23, 2009 | 06:38 PM
its 1-3-4-2....but i dont remember for sure where #1 is on the dizzy...i think its the lower output nearest the firewall. im sure a search would yield the answer though....probably clean the plugs off to, they might be covered in fuel by now.
Old Jul 23, 2009 | 06:39 PM
Here ya go.
Old Jul 23, 2009 | 07:14 PM
well imma try everything tommrow.... hope this works out
Old Jul 23, 2009 | 07:44 PM
that pic above looks like its for a single cam....heres the b-series firing order on the dizzy with pics...
https://honda-tech.com/forums/showth...g+order+series
Old Jul 24, 2009 | 06:46 AM
bump
for more help
Old Jul 24, 2009 | 04:35 PM
waaBAAH's Avatar
like stated above 3 diffrent times.. backfiring through intake sounds like eitehr firing order not correct..or timing is not dead on.
if timing is NOT dead on then you would have low compression.
also with brand new pistons and rings, i would assume a "wet" compression test would yield way better results. put about a tablespoon of oil on top of the pistons..then do a compression check if it worries you that much.
backfiring through intake is wrong firing order either by spark plugs wires in the wrong order or timing (essentially opening valves at wrong time)
Old Jul 24, 2009 | 04:51 PM
jayWknight's Avatar
Did you have the pressure checked, vacuum checked and head surface decked? If the valve seats are leaking then that can a reason for the lower compression numbers. Timing belt might be off and firing order can be off as well.
Old Jul 24, 2009 | 07:17 PM
spark, firing order, fuel, and timing would be the first 4 things to check....and it takes about 5 minutes.
Old Jul 24, 2009 | 07:28 PM
well um headgasket didnt seal porperly and the intake gasket wasnt even there!!!! i think once this is str8ten out everythin migh run right lol
