Aluminum Welding Woes
Old Jul 23, 2009 | 03:59 PM
gman105's Avatar
Default Aluminum Welding Woes
I am a complete noob to welding. I am looking to learn so I can fab up my own charge pipes, exhausts...etc. At the end of day 1, after switching from SS to Al, I had a problem. But first--
Here is the setup:
Diversion 165
CK Worldwide gas lense
3/32 Red tungsten
0-100 amps
Process info:
Scotchbrite and acetone
Tungsten ground to a point (vertically)
Ground clamp directly to workpiece.
Here is the problem description:
Unlike with the SS, I am getting no concentrated-looking arc. Instead I am getting what appears to be a shower. There is no penetration and afterward the work-area appears like normal with a white halo.
Does anyone have any ideas about what is going on?
Thanks.
Old Jul 23, 2009 | 04:07 PM
russianvr4's Avatar
OG Fabricator
Default Re: Aluminum Welding Woes
When welding alum you don't want a sharp tungsten, I usually put my machine on dcep and tap it a bit until the tungsten forms a small ball at the tip
Old Jul 23, 2009 | 04:11 PM
gman105's Avatar
Thanks! That would make sense.
Are inverter and transformer type machines different in this regard? Or does the tungsten always have to be balled for aluminum?
Old Jul 23, 2009 | 05:10 PM
m R g S r's Avatar
it will ball up when the machine is on AC anyway.
Old Jul 24, 2009 | 02:39 AM
ROTARY's Avatar
don't ball it, on inverters you want a pointed tungsten with a flat tip.
how thick is the aluminum? have you moved the AC balance? sounds like your welding with insufficient amperage, post a picture.
Old Jul 24, 2009 | 03:44 AM
Bailhatch's Avatar
yup, a truncated point with an inverter machine works best.
Old Jul 24, 2009 | 04:18 AM
SSS's Avatar
SSS
What shielding gas are you using? Straight argon?
Old Jul 24, 2009 | 03:54 PM
Agtronic's Avatar
The arc sounds normal to me. You will never see a clean sharp looking arc on AC.
Old Jul 24, 2009 | 04:07 PM
c jackson's Avatar
threes
Old Jul 24, 2009 | 04:36 PM
k24em2's Avatar
You need to try an inverter on 250hz markku! Don't forget ear plugs
Old Jul 25, 2009 | 04:16 AM
gman105's Avatar
100% argon.
I cannot change the AC balance with the Diversion. I was trying to lay a bead on a piece of 1/4". Maybe the thickness is what got me--I don't know, I was just very surprised to see no weld pool and no arc. I should try a piece of 1/8" to see if I get the same issues.
Old Jul 25, 2009 | 08:41 AM
LA_HONDAS's Avatar
the diversion 165 is rated for 3/16"
try pre heating it and turn your amps all the way up
you shouldnt have a problem with 1/8"
Old Jul 25, 2009 | 09:52 AM
honduh_head's Avatar
good post ^
90Rexx
Welding / Fabrication
12
Aug 19, 2010 02:59 AM
d16sandrail
10
Feb 20, 2010 06:30 AM
shortyz21
25
Jan 7, 2006 04:11 PM
Kyssrt-4
Apr 15, 2005 01:59 PM
@irborne
25
Dec 1, 2004 10:53 AM
