need help taking half-shaft off
They are pretty easy...Remove the outer axle..then there are just a few bolts holdin the halfshaft in..then once those bolts are removed..pry it out at the trans case and done! Not to hard. Do not over pry and damage the aluminum trans case or seal. Try spraying the bolts with PB BLaster or something similar beforehand to help with the bolt removal.
Hakasniodhao
14
Jan 24, 2007 09:21 PM
MeanGreenEG9
Jan 13, 2003 08:17 AM
