weird cel's.
yes i have used the search function already.
93 civic lx. was a d15 automatic, i swapped in a d16z6 with a si tranny.
im using a p06 chipped ecu.
when its cold and i start it, it idles rough and i get either a code 5, and a code 10. OR a code 15. i can't tell.
when its warm, i can restart it and the code(s) go away.
when i rev to 7500 in neutral, i get code 21.
anyone have any ideas?
second.
there is a post here that shows what each code means, it is stickied at the very top of the forum.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
thats where you need to start. with the codes.
you have a iat code (10), a map sensor code(5) or ignition output signal code (15), vtec spool solenoid code (21)
you also need to get a p28 ecu since it is the correct ecu for your motor.
and automatic p28 can be found for cheap and easily converted to manual
