Suspension & Brakes Theory, alignment, spring rates....
coilovers or just lowering springs???
Old Jul 23, 2009 | 09:40 AM
acccord02se's Avatar
Default coilovers or just lowering springs???
alright so i have a 02 accord se,4 cyl,automatic,4 doors...i know the worst=( but i want to lower my car maybe 2" if not a little more,do you guys suggest coilovers or just regular lowering springs?i dont care if the ride is rough i just want it to look decent and not have a huge gap between my tire and wheel wells,if you guys know of any sites that would be very helpful to,thanks.
Old Jul 23, 2009 | 03:49 PM
Null zahlen's Avatar
Default Re: coilovers or just lowering springs???
I went with coilovers, you can lower the car and raise it with the spanner wrenches.
Old Jul 23, 2009 | 07:14 PM
DrZFiNeSt's Avatar
I would get coilovers and do it right the first time.
Old Jul 24, 2009 | 10:42 AM
what about ebay coilovers?what are some good sites for coilovers?
Old Jul 25, 2009 | 01:12 PM
www.skunk2.com
Old Jul 25, 2009 | 01:20 PM
racebum's Avatar
this is a decent ebay coilover
http://cgi.ebay.com/ebaymotors/APEXI...ht_2705wt_1304
do some research before you buy. a large part of the forum is on koni/gc for one reason. under $1000 nothing will touch its flexibility. rates and rebound are adjustable with this combo. the PIC apex which is the same price offers some rate changes to be made but no damper adjustibility. either of which is a great $800 suspension by the way.
Old Jul 25, 2009 | 03:23 PM
yoontim23's Avatar
coilovers
Old Jul 26, 2009 | 10:45 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
With coilovers you will need high quality shocks to handle the stiff spring rates, like Koni Sport or Tokico Illumina. Tokico HP's or KYB AGX are NOT suitable for use with adjustable coilovers.
Also remember that you will need an alignment every time you adjust the ride height, due to toe changing when ride height changes. And toe is what kills tires. Don't waste money on camber kits, because you don't need them as long as the toe is adjusted to stock specs. See my sticky post in this forum for more info on that.
Old Jul 29, 2009 | 11:46 AM
Xplicitz's Avatar
why not get megan racing coilover?? they have adjustable height and damper in case u want a smooth ride or stiff
Old Jul 29, 2009 | 12:17 PM
JNocon's Avatar
Full Coilovers if you could afford it. Or aftermarket shocks w/ coilover sleeves.
GRAMIREZ5
Suspension & Brakes
25
Sep 19, 2007 06:52 PM
Lex4158
Suspension & Brakes
19
Sep 2, 2007 02:15 PM
vtec99ej
Mar 3, 2007 10:44 AM
7808
Aug 28, 2003 05:12 AM
