what size exh to get ?? 2, 2.25, 2.5
i was thinking about getting custom crush bent exh but i was just curoius on what size is the best for me
pretty much stock d16a6 right now, but later on i plan to have a y8 or a b18 swapped and i dont want to change my exh again after
what motor do you guys have and what size exh ??
all suggestions and pointers would be great
no bigger than 2" if you are still NA...if you've boosted...best to go bigger...around 3"...and try and find a shop that does mandrel bent...it's much better.
Guest
Posts: n/a
totally, i reccomend usuing the diameter of the collector on your header. most are 2". dc's are 2.5 i believe which is too big for NA. im running 2 inch header back no cat and have amazing flow. also whats cool is that the 88 std B pipe is easily accessable from any parts store, only thing you hve to concern yourself with then is a 2" axle back. use the 88 std b pipe if you dont want to run a cat. the header bolts straight into it eliminating room for a cat.
also 2" looks stock which keep the cops off your back
2.25" mendrel custom setup go to a muffler shop in burnaby.
cant think of the name of it but itll be like 400 cdn.
do they do real mandrel bends or just looks like mandrel bends
cuz i called every muffler shop and no one has it, and a few muffler shops told me that if a shop tells you they have a mandrel bend machine then they are BS'ing
gonna run either a test pipe or high flow cat (havent decided)
custom cat back with a dynomax ultraflo
what do you guys think ?? ok setup ??
well i was planning on running a 2.25
but 2.25 piping isnt gonna be the actual flow size cuz if i use crush bend and the smallest part of the bend is gonna be like 2.1x so its actually gonna be a 2.1x cat back
does anyone here run a 2.25 cat back ?? how does it compare to a 2 cat back ??
89 CRX si. where in burnaby is that shop i have called everywhere for someone with a mandrel and each shop keeps saying there isnt any in BC which i know isnt true.
no ones gonna spend XXX thousand amount of dollars just to satisfy a few car guys
and most of the car guys go for pre-fab exhs like dc, greddy, hks...... etc
be warned that were are a few midas that i called that claimed to have a mandrel bend machine and when i went there to check it out, it was just a fancy crush bend
An alternative would be to buy mandrel bent pipes from your local Lordco or parts store & bring them to an exhaust shop to cut & weld for true mandrel bent exhaust system. Or you can spend more for a shop like this. http://www.lr-racing.com/exhaust.htm They are kinda pricey but as you can see from the pics. They make the aftermarket guys look bad!
i have 2.25 inch without cat on my I/H/E d16a6. it is great. i have no complaints, lost a little low end but it made up for it with GREAT top end pull.
i got 2.5" Mandrel bent Airmass Cat-Back exaust with A high Flow cat, With my stock ZC.. i lost a little low end but i picked up a lot of top end power.
